turbo overboosting
a3james May 1, 2012
  1. a3james
    a3james Member
    Audi a3 2.0 tdi has been going into limp mode now and then which won't let it go past 60 if I turn it off and start it straight up again it will be fine. I've had it plugged into a scanner and I said turbocharger overboosting is this likely to be a sensor ? Thanks
  2. BuckleyTDI
    BuckleyTDI Member
    94
    do u know if the 8p a3 run vnt turbos or not? what bhp version is it? and how many miles has the a3 done?
    james
  3. SAiLO
    SAiLO Well-Known Member VCDS Map User
    1,075
    62
    It's likely to be the turbo starting to fail. You can get it replaced for roughly £500
  4. a3james
    a3james Member
    Hi mate its a 2005 2.0 tdi s line with 115000 on the clock cheers
  5. mike foster
    3,967
    BKD engine turbos are all suspect, particularly at that mileage.
    I think you'll have to bite the bullet and go for a reconditioned replacement.
    I had one at 75k miles - £695 fitted and guaranteed for two years.
  6. a3james
    a3james Member
    I don't know whether anyone has had any experience with midland turbo but I spoke to them and they said they charge 185 pound + vat to recon it which includes changing bearings and seals and a relly good clean up. Is that the road to go down ? Or do you recommend and others ? Thanks
  7. N8
    17,163
    718
    Vanes are sticking, same thing happened to me, and this happened:
    :laugh:
  8. mike foster
    3,967
    Did it arrive ok ?
  9. N8
    17,163
    718
    I believe so brother, it arrived @ the bodyshop :wub:
  10. Farhan
    Farhan Active Member
    1,234
    57
    LOL informative MR K. Good stuff what kind of power will the hybrid and shark offer?
  11. Sheikh
    Sheikh Member
    654
    20
    Yeah but you have to appreciate changing to a hybrid means a potential new clutch and a remap. Which is another £1000 easy on top of the turbo. Easier/cheaper to just get a refurb if your not that bothered.
  12. N8
    17,163
    718
    The turbo is good enough for 230bhp with an S3 I/C & uprated injectors, but I'll come to that later in the year :wub:
  13. rob_watti
    rob_watti Member
    62
  14. Brodster
    Brodster Well-Known Member Team Ibis VCDS Map User Audi S4 Audi Avant Owner Group
    3,548
    883
    My old 2.0 TDI - the wastegate acuating arm had failed. It was the integral piece that had gone so new turbo needed.....under warranty no less.......ouch!!
  15. a3james
    a3james Member
    So do you think it would be as good as new if midland turbo recon it ? Will it damage the turbo if I carry on driving it ? Thanks for your help.
  16. mike foster
    3,967
    It won't do any more harm to a knackered turbo but, if it blows, you could be looking at a new engine !
  17. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    midland turbos are very good ive seen there work.
    i got my hybrid from turbo technics and is working fine
  18. - Jrd -
    - Jrd - Member
    107
    I fully recommend Turbo Technics, Customer service is excellent as is there items
  19. N8
    17,163
    718
    This was my first port of call. I've spoke to many people over the past week regarding my issue, lots saying try innotec it's great, others saying its a waste of time! I have a 2000+ mile round trip to Austria pending in the next 2 weeks, and just couldn't drive that distance without knowing that everything was ok. So when replacing the turbo, makes sense to uprate it! I already have the TBE, just need to get S3 intercooler and uprated injectors later in the year to accompany it!
    Looking forward to the car driving nice across the continent! :wub:
  20. mike foster
    3,967
    Have a good trip and don't forget the breathaliser ! Mandatory now in France !!
  21. weela89
    weela89 Member
    64
    Hi,
    I have exactly the same problem on A3 2.0tdi Sportback.
    Ive come round to the fact its the turbo but only gone into Limp Mode twice on the motorway with Cruise Control on.
    Any suggestions for the best place to take the money guzzling beast in the North West, Bolton/Manchester area?
  22. weela89
    weela89 Member
    64
    FYI - I stupidly had the sensor replaced but this was no help.
  23. Sheikh
    Sheikh Member
    654
    20
    Any of you hybrid boys got an idea of what sort of MPG is possible with the hybrid?
  24. rob_watti
    rob_watti Member
    62
    Im in skipton, North Yorkshire if that's any good to you pal?
  25. - Jrd -
    - Jrd - Member
    107
    Which hybrid you got N8? Stage1 your current injectors are OK, Stage 2 youll need injectors. You need the S3 cooler either way and a wider necked downpipe/decat.
    Im doing mine very soon aswell
  26. weela89
    weela89 Member
    64
    I'll have a shop around and let you know if thats ok. Got a mate who is pretty nifty so ill get a price from his first and let you know.
    Cheers,
    Matt
  27. flying oyster
    flying oyster flying oyster
    563
    27
    i got 51 mpg but if your worried about mpg dont get a hybrid because you wont want to think about mpg just on how well your car goes and you will need a new clutch unless your dsg as they a are bit more hardy
  28. N8
    17,163
    718
    Hybrid of my Garrett, I'll be ok without the cooler and injectors for now, I already have a TBE.
  29. J8TT X
    J8TT X Member
    360
    9
    I used Midland Turbos for my recon turbo.
    Very happy with the work.
    Its been on 6 months now.
