turbo or dv
jimmer 22 Aug 3, 2013
  1. jimmer 22
    jimmer 22 Member
    66
    I have just repaired a couple quite bad leaks on the pcv system. Bad enough that I couldn't even get over 5 psi in the system with my leak tester. Its still not perfect but its a hundred times better. I will be getin rid of the hole system as soon as i can so it will do for now. Iv took it out for a run and the turbo sounds alot louder, at least I think its the turbo. Would this be normal? Only other thing I can think of is that the crappy standard recirc valve isnt workin properly. Boost seems slightly spikey aswell. Any input greatly appreciated. Cheers
  2. chaz20vt
    chaz20vt Member
    428
    21
    Have you had it on vcds mate?
  3. 16Klappe
    16Klappe I <3 Panda's! Supporter
    5,795
    1,186
    The "crappy" standard 710N is better than almost all "aftermarket" valves.
    Put a new 710N on and see what happens. £31inc VAT at TPS.
  4. treebo88
    treebo88 New Member
    26
    Take the original dv off mate and check around the nipple on the top as they tend to crack around the nipple and the edges next to the nipple, had the same prob with mine so ive put another on and now i have good boost :)
  5. jimmer 22
    jimmer 22 Member
    66
    cheers guys. have replaced it with a forge 007p and is alot better
  6. 16Klappe
    5,795
    1,186
    For **** sake.
  7. jimmer 22
    jimmer 22 Member
    66
    Lol whats up 16klappe. Thought these were the best valves to put on these....
  8. 16Klappe
    5,795
    1,186
    As per this ^ and 99.9% of people who know what they are talking abouts recommendations.
    007p valves look great and can work just as well as a standard valve, but often don't seal correctly and require maintenance and regular pressure testing.
    Make sure you have the revised piston with rubber o-ring, otherwise you are just putting off the inevitable and will end up for a scored piston and worn sealing surface which will mean lapping in and resealing.
    A DV only does one job, relieve pressure from the pressurised intake tract. A stock DV does an excellent job of sealing and relieving pressure quickly.
    A stronger sprung 007p will in theory only release pressure slower. And as the pressure on the top of a 007p (and stock DV) is pressurising the seal as well as providing the suction to open the valve the weaker the return spring you can get away with the better.
    A stock DV is PERFECT for our cars on their standard turbo up to as much air (and beyond) as our stock turbos can flow an compress.
    Did you buy new or second hand?
  9. 16Klappe
    5,795
    1,186
  10. jimmer 22
    jimmer 22 Member
    66
    Ah, ok. Well now I know. Lol. I bought a new one. I read a couple of threads on here saying that the 007p works great with a badger5 intake kit, which is next on my order list so I went with that.
    Cheers for your input tho.
    I know for next time
  11. 16Klappe
    5,795
    1,186
    If you bought new it should have the rubberised o-ring, so should work just as well as standard but look more bling.
    B5 TIP is a must have for a K04 :)
    Sorry if I seem grumpy, I am generally.
    azman likes this.
  12. jimmer 22
    jimmer 22 Member
    66
    Haha. No worries mate. Yeah like I said its first on the list. And its a long list, lol.
  13. fanta
    fanta Active Member
    240
    32
  14. superkarl
    superkarl MAN OF STEEL
    9,553
    2,453
    The good thing is forge have now realised the flaw in their design after people leak/seal testing them. So if people are buying new then theyre ok, people buying old style ones second hand are the suckers.
    Diaphram valves over piston anyday.
