TURBO ON VAG
vw754 Sep 22, 2009
  1. vw754
    vw754 vorsprung Durch Technik
    2,337
    58
    What does the turbo highlighted in vag-com do? its at top of the screen in 'engine' when you go into vag. TURBO !
  2. bearthebruce
    bearthebruce Ross-Tech, LLC
    343
    21
    It enables faster communications on certain engine controllers. Best used when reading live data from the measuring blocks to increase sample rate. Not all controllers support it.
  3. NHN
    29,352
    1,720
    Am I right in saying Bruce, best used on single MB's as using 2-3 slows it down, not really noticeable but I did read that correctly somewhere didnt I?
  4. bearthebruce
    343
    21
    Hi Nigel,
    Correct. Sort of -
    If the all the measuring blocks are in the same group, then there should not be much difference in speed of update.
    When you view multiple groups, speed of the reports of values will drop drastically.
    So, if you want fastest results, look for a group that has all the parameters you want to view in it. This will give you the fastest results.
