turbo laggggggggg
NOZ Apr 21, 2013
  1. NOZ
    NOZ Member
    209
    21
    hi can someone shed some light on what sort of gap, if indeed any should the turbo kick in ? i've a 2.0tdi s-line, this is the first time ive had a diesel car although i have driven many, and have always thought there should be a small lag when you sink the boot before it kicks in and then pulls like a horse, or should it be more or less instant ?
    and what can i look for and check
    thanks Noz
  2. Molnboman
    Molnboman Well-Known Member
    1,338
    193
    I never had an Audi oil burner but have had plenty of Fords and GM diesels. It depends how you determine turbo lag...I thought that even on the B7's the engine lag shouldn't be that noticeable, and thought it applied to the older diesel engines. Has your car been recently serviced or have you had a diagnostic check done at your friendly local garage. That may throw up a few clues to the explanation of any turbo lag you may be experiencing.
    A
  3. Steve220
    Steve220 Member
    234
    15
    You shouldn't feel lag, it's should be progressive as your car uses variable vane.
  4. NOZ
    NOZ Member
    209
    21
    thanks guys think i will get a service, i know its due in about 1400 miles but might get it done early and mention it to them to see what they find
  5. Molnboman
    1,338
    193
  6. Steve220
    Steve220 Member
    234
    15
    It could also be your egr valve clogged up. Seems as if some problems for late boost come down to this annoying little item on the engine.
