Turbo Lag
Grant Jan 12, 2004
  1. Grant
    Grant Well-Known Member VCDS Map User Audi RS3
    1,206
    118
    Is there anyway that turbo lag could be reduce on the S3? I understand an electronic boost controller could be used to set when the turbo kicks in, but is there any other ways bar a boost controller?
  2. dbm
    dbm Active Member
    655
    195
    43
    As I understand it (and I am not a mechanic), de-restricting the airflow in the turbo system (eg changing the exhaust and cat) will help.
    My personal experience seems to fit with this as I have a switchable chip in my car, as well as free-flow exhaust and cat. Even when in stock mode the car is much more easy reving than it used to be.
    Dan
  3. Ess_Three
    Ess_Three Active Member
    5,383
    [ QUOTE ]
    [/ QUOTE ]
    I don't believe so.
    Mine has no less lag now than on the standard stuff...the fact that the S3 runs a larger compressor wheel in a larger housing than a K03 turbo in an A3 / Golf will always mean that there is slightly more lag.
    Exhaust, cats, modified airbox, modified turbo pipework, air filter etc all add to the engines response whilst not on boost...but won't reduce the lag. Not on mine anyway.
    But to be honest, anyone that complaines about the lag on an S3 should go back in time and drive an RS turbo or early big turbo Escort Cossie...then it'll remind you of just how little lag the S3 really has!
  4. StephenBogan
    StephenBogan Member
    253
    What lag?!! A wee second just to give your passangers a chance to hold on!
  5. HTC
    HTC Active Member
    3,428
    9
    LOL!! I like your way of thinking.
  6. Mike.M
    Mike.M Well-Known Member
    2,510
    170
    I just took the lower fog lights out of my S3 as they resist the air flow to the inter coolers esp the drivers side one...........have a look at your own car.
    I have noticed the car when it has properly warmed up, feels more responsive now due to the better cooling.
