turbo lag
bigpaul Dec 17, 2006
  1. bigpaul
    bigpaul New Member
    13
    :wub: looking for a little advice!! since this is my first diesel Audi i was wondering if the turbo lag is a common thing ! i have been caught out a couple of times when accelerating away at junctions, roundabouts when there's no power there for a couple of seconds,.
    whats the best way around this problem as Am not very mechanically minded?
    ps its a a4 19tdi sport
  2. james0808
    james0808 Active Member
    3,548
    I dont really notice any lag on mine.You could give it a few more revs and slip the clutch on fast pull offs.
  3. Jason
    Jason Member
    188
    Sounds more like your Maf than turbo lag!!!
  4. evomaster3000
    evomaster3000 Member
    449
    yeah could be MAF sensor, try driving another diesel VAG if poss n compare, it could be that ur not used to diesels but if u drive em like a petrol u shouldn't notice lag unless ur pullin away at 1krpm (like i do lol)
  5. bigpaul
    bigpaul New Member
    13
    thanks 4 the advice could any one explaine the maf senser what it does & where is it locaited & if possible how to alter it thanks again .........:meeting:
  6. inigoj
    inigoj Member
    263
    If your TDI is pre 2001, your turbo should come online around 1700rpm.
    If you put your foot down you should be able to wheel spin from a standing start no matter what the conditions.
    Your MAF measures air density and flow rate, so that the engine knows how much fuel to add to the mix. It is located on the cold air inlet to the airbox behind your drivers headlight (depending on engine orientation).
    If your MAF is not at fault a cheap 'tuning box' may solve your power problems, most just keep the injectors open for a fraction of a second longer, adding more diesel = more power.
    If your ECU is flashable you could also have the rpm that the turbo comes on-line altered, but this will shorten the life of your turbo amongst other things.
  7. bigpaul
    bigpaul New Member
    13
    :rockwoot: thanks 4 that inigoj by the way its a 2003 model
