Turbo issue maybe????
temp Dec 5, 2013
  1. temp
    temp Member
    74
    This morning car started with a funny noise like a whining noise and a loss of power not sure if it's a leak in the system or f**k turbo. Cars not smoking. Any advice.
  2. cammage08
    cammage08 Member
    171
    10
    I'm pretty sure your best option is to get it scanned asap... Any fault codes will help loads..
  3. temp
    temp Member
    74
    Had it plugged into vag but no codes
  4. Machine212
    Machine212 Active Member
    120
    30
    This was mine two weeks ago, does it sound like this? Mine had two fins on the turbo chipped off and loads of play.
    VID 20131118 073149 - YouTube
  5. JoeeS3
    JoeeS3 Active Member
    464
    105
    43
  6. temp
    temp Member
    74
    Yes it does sound abit like that!!! What is it??? Plz!!!
  7. JoeeS3
    464
    105
    43
    not sure if you have seen any of my posts but unfortunately it sounds as if its your turbo gone bud. i'm having my k04 changed today. do you have an s3 or a3?
  8. temp
    temp Member
    74
    S3 that what I did not want to hear how much is it costing.
  9. JoeeS3
    464
    105
    43
    but i'm no mechanic. that video is of my car though and it seemed on the older turbo(chinese knock off) that there was a lot of play in the shaft, so the blades were touching the housing which was causing the whine.
  10. JoeeS3
    464
    105
    43
    well i bought a second hand turbo for the time being for 190 delivered (Genuine) but i'm getting a hyrbrid sometime in the new year. if your not planning on doing that speak to dan at beach buggy turbos and he should be able to sort something out for you. hope this helps
  11. JoeeS3
    464
    105
    43
    and then the fitting for me is 200 as i know the person doing it.
  12. temp
    temp Member
    74
    What sort of turbo is on a standard s3 k03 or k04 which is best and what do you need to upgrade if put the better one on. My car is standard and want to upgrade stuff and if it needs a new turned might as well start now.
  13. Sean_S3
    Sean_S3 Member
    308
    K04 standard on an S3 , if you wanted to upgrade you would be looking at a K04 hybrid turbo.
  14. temp
    temp Member
    74
  15. JoeeS3
    464
    105
    43
    there isnt anything to click on mate
  16. temp
    temp Member
    74
    Not sure how to put vids on through my phone it was a vid of the noise drove car 2 day about 15miles no power, or smoke?? Stripped it down to the turbo the other night and all still there and no play in fin's somebody said my cat might of broken up and blocking the exhaust???? Not sure????
