turbo intercooler hose clip
BeeKay Sep 13, 2012
  1. BeeKay
    BeeKay Member
    68
    ok so ive got myself a 1.9 tdi 130 bhp was driving completely fine then i hear a pop n see a cloud of smoke pulled over cracked open the bonnet to find the intercooler pipe at the front of the engine had come off found out that the clip is messed up , anyone know where i can get a new clip picture of it below
  2. Paradox1
    Paradox1 Well-Known Member
    1,833
    88
    Ant view pics at the moment but ud recommend getting a hve stainless clamps.you can get them on ebay
  3. Lewis583
    956
    91
    The clip looks fine to me from that picture. You will probably find the metal coupling on the intercooler hose has worn. I would take the hose off and inspect the coupling.
    Both clip and hose will be availabe from main dealers.
  4. BeeKay
    BeeKay Member
    68
    thanks for the replys will take a look , i just went to a audi stealership but the parts section had closed :( from reading around ive seen there 30 quid for the pipe and the clips
  5. BeeKay
    BeeKay Member
    68
    ok after taking the pipe completely out abd inspecting its deffo not rhe pipe see 1st pic looks completely fine , after going further back i looked at the thing it clamps onto it comes out as the intercooler is also clipped onto this attachment taken pics of it looks worn out round the edges see 2nd pic when i turned it around and clipped it onto the other side it worked fine for a while ( has the same type of teeth both sides) i even had a good blast in the car but 2 hours later it came off again , anyone know what its called and where i can get one from trying to aviod a stealership as much as i can bad experiance , also the top of my pipe looked very dirty looks like i need to clean the carb see pic 3
  6. Lewis583
    956
    91
    Yeah i thought the coupling would have been worn. Unfortunately you have to buy a new boost pipe mate as the coupling and hose can't be separated. AFAIK the hose is dealer only aswell
  7. BeeKay
    BeeKay Member
    68
    thanks for your reply it was the bottom coupling that was worn this is detachable see pic attached
  8. BeeKay
    BeeKay Member
    68
    got it fixed was a 30 quid part ( pic attached ) gave it a good blast drives like a dream now
    will add part number for refrence should anyone have the same prob might come in handy :)
