Turbo Hose And Tip Removal!
Dani_B19 Jun 14, 2009
  1. Dani_B19
    9,320
    389
    Whats the best way to get to the turbo to remove the turbo hose and the tip?
    Just had the strut brace off but was towing like hell to get to where the turbo hose and tip connect to the turbo.
    Would it be best to remove the airbox and go in that way?
  2. abdus
    abdus Top Gear VCDS Map User
    1,827
    removing the turbo will help greatly and working from underneath
  3. abdus
    1,827
  4. Dani_B19
    9,320
    389
    Cheers abdus.
    Anyone done this from the top without getting under the car or removing the turbo?
  5. abdus
    1,827
    well, getting under the car would be easier. There no need to remove the turbo
  6. Dani_B19
    9,320
    389
    Didnt think you'd be able to get to it, so would it be best to jack the drivers side up then, would that allow me to get to the turbo hose aswell!
  7. <tuffty/>
    21,355
    3,922
    I removed the air box to do mine, not difficult and saves loads of time and hassle. That was on my car of course, not sure is non ESP cars are that much different.
    IIRC you unscrew the top of the air box (as if changing the filter) making sure you have undo the TIP from the MAF. There are a couple of 10mm bolts holding the bottom half of the airbox on then there is loads of room to get your hand in (from the top) to the jubilee clip holding the TIP to the turbo.
  8. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    I did mine from the top without needing to take airbox or turbo off lol
    Easy realy
  9. Dani_B19
    9,320
    389
    Paul was that for the tip or the turbo hose?
  10. Dani_B19
    9,320
    389
    Wish mine was going tobe that easy, mine non esp so im having to moify the pipes that connect to the tip.
  11. ianysm
    ianysm Active Member
    1,002
    What difference does the addition of the new TIP make out of interest?
    Might consider changing mine (stage one car)
  12. Dani_B19
    9,320
    389
    Just more free flowing and is ment to allow more air tobe pulled through by the turbo and looks cool haha.
  13. jojo
    28,907
    3,563
    It also reduces heatsoak.
  14. S3APY
    S3APY Member
    127
  15. 1animal1
    9,978
    you guys take off the strut/airbox and even turbo!!! haha....im with Paul, ive fitted 3 of the damn things now - armed with a wrench to undo the jubilees and a small screw driver to wrestle off the Audi clips..... simples
  16. vanilla_ice
    vanilla_ice Active Member
    707
    Why would Jabbasport have told me that all a new TIP would give me is a lighter wallet? :confused:
    ICE
  17. HTC
    HTC Active Member
    3,428
    9
  18. ianysm
    1,002
    I assume it makes more difference on a mapped car than stock. I'm tempted!
  19. 1animal1
    9,978
    na the only reason that most assume is due to the forge vid of one collapsing on a TT under load......thing is there was several redesigned OEM TIP's and mine for one was stronger than my silicone one.... i wouldnt pay full price for silicone jobby based on that fact (and i didnt)
    Car made a bit more of a whoosh noise and thats all i can recall looking back,...... although the one i replaced had slight corrosion that would have caused an issue down the line
  20. Dani_B19
    9,320
    389
    So how did you get to yours then tim?
  21. 1animal1
    9,978
    just removed the engine plastic cover..... and took it all to pieces from the top mate.... the hardest bit is undoing and retightening the TIP onto the turbo, if you get a small wrench with the right size bit you can feel around and sort it easy enough.... its a bit tiring on the backs of ya legs and your guaranteed to be walking funny for the following hour or so, but really is that simple
  22. 1animal1
    9,978
    if ya strugglin ya can always bring it to me one evening mate, either that or i would imagine Paul would sort it for ya, takes about 30-40mins tops
  23. Dani_B19
    9,320
    389
    Cheers pal, ill be ok doing it just wanted to know people's thoughts on the best way to get at it. Well got all my bits coming this week, turbo hose, catch tank etc etc cant wait :yahoo:.
