turbo help needed asap please
S3featesV9 Feb 17, 2012
  1. S3featesV9
    S3featesV9 Active Member
    1,032
    12
    ok so garage have just called me saying they can get hold of a new turbo for me today but its quite expensive £514 or something.
    so they called to say its up to me, id rather get one cheaper, obviously.
    i found this on ebay...
    K04 - 023 Audi S3 TT Quattro Seat Leon 1.8L BAM Turbo Turbocharger New | eBay
    is that what id need for my 2002 BAM S3?
    (if someone had one in fully working condition that i could pick up today it would be a massive help pm me)
    been without my car for 2 weeks and its driving me mad!!
  2. <tuffty/>
    21,575
    4,048
    Chinese... avoid....
    £514 sounds a decent price tbh... would be a refurb unit at a guess....
    CR Turbos may have a refurb on the shelf but I don't think it would be much cheaper... from VAG they are quite expensive...
  3. Westy
    Westy Well-Known Member
    17,443
    1,105
    What's up with your turbo?
    Have you contacted Bill? He did have 2 or 3 refurbed K04s kicking about at one point that were selling for £250. He might have some more.
  4. <tuffty/>
    21,575
    4,048
    ...should mention you can't buy a genuine K04 for £200 that is new....
  5. S3featesV9
    1,032
    12
    i knew i could count on a reply from you, cheers tuffty!!! on phone to CR turbos now
  6. Westy
    17,443
    1,105
    My brand new K04 from Turbo Dynamics was something along the lines of £800 :faint:
  7. S3featesV9
    1,032
    12
    OUCH. yeah CR can do me a recon on mine for 395 but have to build it up, post it to me. so will take over a week. im being impatient and WANT one today lol.
    so whatever the price is im willing to pay at the moment. Wonder if Bill could source me one?
  8. Westy
    17,443
    1,105
    Mine originally went off to Turbo Dynamics for a refurb but was beyond repair :( what's up with your turbo?
  9. S3featesV9
    1,032
    12
    Apparently everything on exhaust side is knackered. Haven't been up to see it yet. Probably is repairable. But I was thing get a new one, or reconditioned today. Then get mine fixed and sell it take make some money back.
    Popping up in an hour, will take a pic. They said something about being sheared off, sounds pretty shot to me. I was boosting ok though, 26psi according to gauge.
  10. Westy
    17,443
    1,105
    Have they said whether it is repairable?
  11. <tuffty/>
    21,575
    4,048
    At that boost I expect the hotside to be a mess... all the K04's I have seen that have run high boost end up like that... Welly will have a pic of his and have taken one off a TT recently that looks much the same...
  12. Westy
    17,443
    1,105
    I expect mine to be ruined pretty quickly then once the engine is built :(
  13. Welly
    Welly VX220 SC Driver :)
    10,696
    129
    Welly does....
  14. S3featesV9
    1,032
    12
    That haven't said yet no. Said the balls in my court weather I send it off to see if it's repairable or not. So just going to get a new one fitted so I get car back sooner. Then look into having old one repaired. If so I'll then sell it on if it's cost effective etc. garage have ordered one from where I'm not sure will be with them Monday.
  15. Westy
    17,443
    1,105
    Did Sandip sell his K04? Might be worth asking him.
  16. <tuffty/>
    21,575
    4,048
    I don't expect there will be a reason to run that kinda boost level mate... normally you will hit a point where more boost won't give more power but just increases heat generation (and EGT's) and lifts torque... assuming you are coming to Bill's for tweaks once done he will ensure a safe tune...
    It will be high EGT's that cause this type of damage... boost level is irrelevant in context as on some setups you can get high EGT's on less boost... simply put if you can get away with using 26psi as EGT's and other critical areas are fine then all will be good... if EGT's go into the protection zone then its best to turn it down...
    Don't forget more boost doesn't mean more power and don't get fixated on it... there is timing advance and total flow to consider... boost is there to force airflow... when you hit that barrier of airflow then no amount of boost will help :)
    Really looking forward to seeing the results of this
  17. S3featesV9
    1,032
    12
    I think when my car is up and running I need a booking with bill to go over the map I think. I didn't get it done, previous owner did. So don't have any idea what its at.
  18. Westy
    17,443
    1,105
    IT was a cheap nasty map that killed my turbo and fuel pump. Went to Bill and he made everything right again.
  19. S3featesV9
    1,032
    12
    The bloke does no his stuff doesn't he. Where is he based, I'm Oxford?
  20. Westy
    17,443
    1,105
    He's in Stonehouse near Gloucester. I'm in Herts and he's 2 and half hours from me but worth the journey.
