Turbo gone :( - Could do with some advice
Napbree Jan 15, 2014
  1. Napbree
    Napbree Member
    136
    13
    Hey guys,
    So a great start to the new year... I've nearly gone blind and had to have retinal detachment surgery and now my turbo has gone on my car.
    A family member took it into audi for me and asked them to give it a once over and to do the following:
    • New turbo
    • the starting is lethargic in the morning when its cold, advise
    • diagnose the resonance in the back of the car between 60-80 (most likely down to the propshaft donut?)
    They've got back to me and said that the turbo needs replacing (fair enough) and the battery because thats causing the poor starting. But the resonance in the back of the car is down to the turbo (I call bull****).
    Oh and they want £1650 for a new turbo and new battery (not sure if this is including vat, need to double check).
    My question to you guys is, would it be more economical to get the turbo refurbed or to get the turbo from elsewhere, if so any suggestions?
    It's probably worth mentioning thats its been remapped and I don't want a cheap **** turbo!
  2. hollows wife
    hollows wife Well-Known Member
    1,404
    164
    you could buy a brand new turbo from tps for a lot less than that and either fit it yourself or get an indy to fit it , please dont buy a cheap aftermarket one from ebay it will be knackered in a few months , also dont get a recon same applies . i would rather buy a good secondhand unit rather than a recon . sounds like the battery could have cell damage and is loosing cranking power .
    resonance no idea without hearing it .could be a number of things
    theres a genuine secondhand unit for the 170 on ebay for £200 if you dont want to be spending loads .
    mozza1202 likes this.
  3. Brodster
    Brodster Well-Known Member TeamMisano Team V8 Audi RS4 Audi Avant Owner Group s tronic
    3,553
    896
    Afew guys on here do turbos...........xman750 and Dan@Beachuggy turbos both do great deals on replacements or hybrid or whatever route you wanna go down. Give them a PM and see what their prices are like. A lot cheaper than the dealers.
  4. Sidhu88
    Sidhu88 Active Member
    808
    76
    Alongside changing the turbo you should consider doing an oil service and maybe replacing oil feed lines. Thats what i was advised to do when i bought mine (which i still havent changed). I thought my turbo was going, turned out it was two massive boost leaks, so i still have mine sitting around at home.
  5. Napbree
    Napbree Member
    136
    13
  6. hollows wife
    1,404
    164
    nephew had one for his 170 a4 which is very similar . cost him £1300 inc vat from them .then a remap at rs in leeds £ 500 . turbo struggled to get 235bhp . masses of torque though, too much in fact .
    hell of a lot of coin for 30 bhp . swapped it not long after for a golf edition 30 . since then the hybrid turbo is dead hotside melted away .
    turbo is or was around 8 months old .
  7. Napbree
    Napbree Member
    136
    13
    That's what I heard that they run hot, something to do with the EGTs?
    Thing is, I wouldn't want Rick the tuner to push the car, I would want a smother torque line than what I have now (I have about 190 as it stands) so maybe push it to 200-210. I'd want reliability over performance.
    So probably not worth it then, I just have this upgrade bug - e.g. if something breaks, replace it with something thats better!
  8. hades-
    9,482
    646
    dont put the lad off recon turbos
    iv had at least over 50 done for diffrent cars
    and they can and do last very good miles
    buying secondhand is a gamble
  9. hollows wife
    1,404
    164
    might as well buy a gt 2260 then and do the injector swap ,go to around 290 bhp
  10. hollows wife
    1,404
    164
    the recon route is a gamble just like secondhand ,but if you read the warranty for a recon turbo it always states to replace the oil feed pipe to the turbo and it has to be fitted to a competent trained mechanic . ive stood in the garage before whilst we have had these arguments with turbo companies on the phone when they try to wriggle out of warranty claims on recon turbos.
  11. hades-
    9,482
    646
    yeah i agree all turbos should be refitted with a feed pipe and oil and filter
    kinda daft not to and i wouldnt replace under warranty any that hadnt been fitted with new feed pipe.
    but if fitted correct and a fault shows then they will sort them on a claim.
  12. hollows wife
    1,404
    164
    must have better luck than we do then ,except for the obvious self destructing ones .
  13. davc
    davc Well-Known Member Team Glacier Audi S3 quattro s tronic S3 Saloon saloon
    659
    666
    93
    Turbo Dynamics are a reputable name. I ran an MD376 on a pd150 for over 30k miles with no issues whatsoever, but my car was custom mapped and EGT's weren't excessive. I would choose one of their units over a recon'd one every time.
    At the end of the day, turbo reliability is partly down to how the car is mapped.
  14. shinsplint
    shinsplint Member
    110
    Regarding the resonance through the back of the car, I get this at a specific rev range, usually about 2.5k revs driving steady, most noticeable in 5th or 6th gear. Can be quite frustrating and I generally just accelerate a touch until it goes. No idea what causes it though, maybe a slight exhaust issue??
  15. sliced
    sliced Drive safe, stay alive.
    1,568
    335
    you had a new turbo done recently to it, and its gone again?! I would see if there was warranty on that new turbo if its been under a year
