Turbo fin's
temp Dec 9, 2013
  1. temp
    temp Member
    74
    My turbo fin's move only a little in and out with NO play up and down is this play in the turbo acceptable or is it knackered.
  2. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    I understand that a little side to side movement is fine. Slack is taken up when the oil flows past the bearings.
  3. desertstorm
    desertstorm Moderator Staff Member Moderator VCDS Map User quattro Audi A4 Audi Avant Owner Group TDi
    6,098
    2,805
    It all depends what kind of bearings are in the turbo. Most have sleeve bearings which use the hydrodynamic properties of oil to produce a bearing surface.These will have a certain amount of play side to side but the turbine or compressor shoudn't be able to touch the housing any where. There should be very little axial movement ( in and out) on the shaft.Some turbo's use bearings with ceramic ball or roller elements, these should have no appreciable movement in either direction.Karl.
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    As said journal bearings have a small bit of play up down, no in out play should be really there..
