turbo exhaust housing wanted
ian52 Apr 5, 2009
  1. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    my k03s exhaust housing has some nice big cracks inside it so could do with a new one if anybody has one from a goosed turbo lying about.not sure if k03 and k03s housings are the same?
  2. Broken Byzan
    13,237
    466
    needs to be from a ko3 mate. You will be lucky to find a housing without cracks in it.
    My hrbrid was rebuilt with a few cracks in it, i have been assured it will cause me no problems. In fact my last unit self destructed and was the sme state of cracing as it was when it went in Its to do with heating and cooliing properly
  3. ian52
    1,199
    my turbo is a k03s so is a housing from a k03 ok? where it has cracked it has touched the turbine but it dont seem to have effected anything. when i took the turbo off one of the bolts that hold it to the manifold snapped inside the turbo housing as well,i got it drilled enough to tap it for a smaller bolt but a new housing would be better.
  4. Broken Byzan
    13,237
    466
    Ahh my mistake, you need a k03s housing then. The spindle will more likely be off balance now too
  5. ian52
    1,199
    there was very minimal play in the turbo so it seems healthy enough. dont think i have much chance of finding a k03s housing then.you can see where the blades have rubbed it slightly but seems not to be a problem anyway.
  6. ian52
    1,199
    bump,still need a housing if anybody has one spare.
  7. aragorn
    18,611
    871
    I'm surprised the turbo is still in one piece if the blades have been clipping the housing.
    Only requires a tiny amount of metal removed from the turbine to knock the shaft out of balance, and once its out of balance it'll shake itself apart in no time...
  8. ian52
    1,199
    looks like it has been that way for a while anyway.just want a new housing on it now.
  9. ian52
    1,199
    anybody? somebody must have one lying about,i just want to have one i know is ok on it now.
  10. stub
    stub the matrix is comin
    143
    i have a ko3 housing hooked up to the turbo. it has a small crack in it but it doesn't blow at all and there is no soot marks on it either. as far as i know the ko3 an kos use the same housin its just whats inside thats diff. but its up to you mate
  11. ian52
    1,199
    if you want to sell the housing ill take it if the price is right. is the turbo goosed? i dont need it.
