Turbo Bullsh*t???
Biggles Dec 12, 2006
  1. Biggles
    Biggles Member
    65
    I have been having low RPM performance issues with my 2.5V6 A6 Allroad. (See my other posts).
    In desperation I went to the local stealership. Very seemingly knowledgeable chap took the car out. His diagnosis is the variable geometry turbo is not working a low engine speeds. He tested the actuator and confirmed it was working OK, but said that the fins inside the turbo could be faulty even thought the actuator works. Something about the variable pitch getting stuck?
    When the car is ticking over the the actuator is in the lifted position, and it is revved up it drops, so looks like something is happening.
    The problem is much worse when the car is cold.
    Any suggestions?
    Biggles
  2. Ess_Three
    Ess_Three Active Member
    5,383
    14
    Diesel?
    If it's anything like the variable vanes on my old mans Golf GT TDI 130, the only cure was a replacement turbo.
    His used to stick in the high boost type position, give too much boost and hit limp mode, and cut all the power.
