Turbo back Milltek Mini-Review
Spin140 May 5, 2009
  1. Jamiekip
    Jamiekip Member
    717
    Exactly!
    I'm sure the cat back has a few advantages, but I'm pretty sure they are minor due to the OEM DP!
    Be interesting to hear from somone who has done only that to date!
  2. Spin140
    Spin140 Well-Known Member
    2,196
    186
    It all makes total sense to me which is why I considered just DP in the first place but I got the same response from 2 different sources so just decided to go with the full system, I'm confident though that the rear section should cause no problems as I too viewed the 2 side by side, first reponse was from a Tech at Graham Goode Racing, Ed at APS had a similar response but was willing to give it a try.
    "Hello Martin
    Thank you for the reply,i have contacted MILLTEK,and they only recomend their large bore downpipe and sports cat be fitted with MILLTEK or any other good quality large bore exhaust system,and NOT with the standard oem system.All to do with exhaust gas temperatures,and the oem system will not handle the temperature and flow rate.Thanks again.
    Kind regards ANDY"
  3. Jamiekip
    Jamiekip Member
    717
    Cheers Spin. Again - appears it's Millteks view on it.
    Well, i've done 5k miles, including 800 miles non stop to the Alps + another 800 back, as well as some pretty heavy driving sessions... no issues as yet.....
    I can almost sense something going wrong now hahaha
  4. hufcforpromotion
    hufcforpromotion New Member
    10
    Of the rear of your car please so I can see what the tailpipe look like!?
    Cheers John
  5. 6andy69
    6andy69 Member
    85
    I think the Milltek cat back system is very good, i fitted mine last night i bought the Non-resonated system (150 off ebay), fits perfect and has the same tail pipes as the standard exhaust so people cant really tell you have a exhaust on till you pull off. The Milltek system is much louder, just need to take the cats out now! :sm4:
  6. Spin140
    2,196
    186
    There are links to the pics in the first post.
    cheers Spin
  7. hufcforpromotion
    10
    Yes seen those mate but being so close in I can't really tell if the tailpipes suit the car! Thanks anyway!
    Cheers John
  8. Spin140
    2,196
    186
    I happen to know you can special order jet style (twin) with rolled edges if you want a more OEM look, if I had known this before placing my order I would have gone with those, don't think it cost you anymore you just have to specify via your local outlet, alternatively order direct.
    Steve at Statller will be able to source them for you - 0114 279 8195
    hope this helps
    Spin
