Tuning a ported Sub enclosure.
Jay Aug 10, 2008
  1. Jay
    Jay Member
    318
    I have an Alipine 12" type R sub in a ported Alpine enclosure. I was wondering if it could be tuned to around 30hz? and how i would go about doing this?
  2. Simon Singh
    Simon Singh BMW Expert
    29
    How do you mean tuned to? To cut off after 30hz?
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    depends on what you mean ?
    do you mean so as the port itself is tuned so as its peak effiecency is at 30hz ? or do you mean you only wish to play music which is above or below this frequency ?
    to stop music below this frequency with a ported enclosure you will need to use a subsonic filter (most good amplifiers have them built in )
    i cant imagine why you would want to ... but if you mean you only wish to play music upto and including 30hz then youll need a low pass filter set to 30 hz
    the box the port and the speaker interact and work as a team it will really depend on what tuning frequency its tuned to now if its fairly high
    then the only way youll be able to achieve a tuning frequency of 30 hz will be by re-designing a new box and port
  4. Jay
    Jay Member
    318
    thanks, looks like it would be easier to buy a sealed box than to redesign a box and the port.
    Next question is would my Mono Alpine M605 amp be able to run 2 12" 1242 type R subs wired in parallel or would I need to buy a new amp?
  5. dunk
    dunk Member
    770
    if its already in a ported alpine enclosure, why do you want to change things?
    if its the swr 1242d sub, then it should live in a sealed box of around 38L, or a tuned box between 45-85L for each sub - quite a big box.
    the 45L tuned box would have a f-3 i.e. -3db point at about 25hz, but its a very peaky boomy box and would only play bass at 1 note (my opinion only) according to the calculations
  6. Jay
    Jay Member
    318
    Exactly...with the new HU I find that its drowing out the music from the fronts. I tested a 12" in a sealed box and it sounded so much better.
    Any ideas on my problem
    "would my Mono Alpine M605 amp be able to run 2 12" 1242 type R subs wired in parallel or would I need to buy a new amp?"
    cheers
  7. AndyMac
    AndyMac Moderator Moderator
    9,832
    46
    That amp should be fine as it kicks out 600wrms at 2 ohms. Your 2 subs in parallel will provide a 2 ohm load.
  8. dualmono21
    1,138
  9. Jay
    Jay Member
    318
  10. two
    two New Member
    custom box which is design to work with your speakers specs
    bass box pro is a great piece of software that does the maths for you
    (also winisd)
    bass box pro help file give a good commentary about different speaker box designs
    i'm about to pop out.. but could work out a box size at some point over the weekend
