  1. Eyeball Paul
    Eyeball Paul New Member
    Ok guys, i have £1700 to spend on tuning my std S3, am thinking Milteck and a chip...
    Any ideas and who would you recorrmend, im in hampshire/surrey
  2. emery1990
    emery1990 Active Member
    1,068
    Youll have more money if you go custom exhaust, but then much easier to get a pre fabricated one.
    You'll need a forge 007 dump valve, as your stock one will stick alot after the remap. there £90. And amd is what i was recommended, as im from hampshire to. they offered around £1300 for milltech exaust and custom remap.
  3. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,146
    1,983
    no chip needed,its all software downloaded to the ecu..remap...also I would spend money on wheels rather than an exhaust
  4. voorhees
    16,146
    1,983
  5. <tuffty/>
    21,016
    3,780
    Suspension first tbh, then a remap... whatever you have left get stuff like exhausts etc...
  6. voorhees
    16,146
    1,983
    thats a good call but a remap is cheaper and more smiles per pound tufty
  7. Dani_B19
    9,174
    363
    Fmic, 3 DP and cat and remap and DV.
  8. mattyboy199
    mattyboy199 Well-Known Member
    1,889
    30
    uprate the DV
    anti roll bars
    exhaust system
    remap
    Should be in the region of £1500
  9. alijames
    alijames Active Member
    1,024
    And don't forget the DS2500 brake pads on the front to make it stop better from warp factor 9!!
    Cheers,
  10. S3 Nattie
    S3 Nattie Quattro ist für sissies
    1,599
    Im doing mine in that order. Trying to find some R32 ARB's for sale, if anyone knows some R32 dudes who have upgraded.
  11. ianysm
    ianysm Active Member
    1,002
    I'd just get remap and better pads to start with then see which way to go once you've driven it like that for abit.
    You might want better handling at that point or choose more power!
  12. Effect
    Effect Member
    469
    i would say suspension, remap and DS2500 brake pads, whatever is left over on small mods like forge 007P etc.
  13. Ess_Three
    Ess_Three Active Member
    5,383
    14
    Generic re-map and sort the brakes.
    Then sort the suspension...that's what will make you quicker A to B.
    Save your money and forget the exhaust if you are keeping the K04 turbo, you will get nothing from changing it, except poor fitting, a squint back box and an annoying knocking - if it's a Milltek.
    Beyond that, FMIC, then start winding up the boost - once you can stop it, and get it to go round corners.
  14. S3 Nattie
    1,599
  15. Ess_Three
    5,383
    14
    Nope. Not if you want performance. It sounds good...but mine knocked at the rear for the 3 1/3 years I had the car and always sat squint.
    It added NOTHING to the power, on the Dyno.
    I would put the money into something that WILL give you a gain - remap, better brakes or into the suspension.
  16. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    What he said. £1000 on brakes....£450 on revo and £250 on whatever else you want.
  17. badger5
    9,434
    1,978
    or £308 on Custom Code
  18. Ess_Three
    5,383
    14
    You can probably get a decent brake upgrade from Bill too, while you are there.
    Should leave you with a car that goes and stops well...and a few quid left over to put towards making it go round corners.
    Winner!
  19. badger5
    9,434
    1,978
    pickup those bargain AP's from Martin Hadland on Ebay and match them to some 323x28 LCR sized disks or 330x28 2-piece if that takes ya fancy, and you will get some nice stoppers for good money. some info in tufftys minor mod build thread (ironic title) of what I'm talking about. an option to consider perhaps.
  20. Essflee
    Essflee Well-Known Member
    2,143
    67
    Obviously a remap, that goes without saying...
    Personally I'd sort the suspension before the brakes unless your going to be visiting a track regularly...I drive quite hard but for the road there's only so long you'll have a mad moment and for me a large amount of money on brakes wouldn't be justified...
    If you track your car often then brakes for sure...
  21. emery1990
    1,068
    And like another memeber said they couldnt afford to replace the £1000+ brake setup, with the same discs and is just now getting normal discs. And like leggy said.
  22. badger5
    9,434
    1,978
    i would get ds2500 pads up front as a minimum myself.. s3 is a heavy ole bus
  23. mattyboy199
    1,889
    30
    i dont think a brake up grade is beneficial with just a remap, with a BT conversation i can understand but my brakes have been fine coping with just a remap, all i m running is standard mintex stuff.
  24. Ess_Three
    5,383
    14
    Why not?
    The weight, and hence mass and momentum of the S3 doesn't change regardless of how much power it has, so you arrive at the braking point for the corner at the same speed, with the same energy to get rid of...only with more power, you accelerate out of it faster.
    Having gone from standard, through 'uprated discs and pads' to proper brakes (4 por Brembos) you'd be surprised just how much quicker an S3 can be point to point when you have better, more progressive brakes.
  25. <tuffty/>
    21,016
    3,780
    I'd be quick though they seem to have started selling like hot cakes. Got a PM from a member that called Martin and he reckoned he only had a few left!!!
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=250455042455
    The auction suggests there are more but if he has sold some outside of ebay and not updated the auction there may not be that many left. I would give him a call.
    Incidently, Bill has the brackets for these...
  26. S3 CYP
    S3 CYP Active Member
    146
    27
    I concer, when I spoke to Martin, only had three left (now two as I have a set).
    I agree with Ess_three's comments reguarding braking and suspension.
    I have found in my 13 years of driving having good brakes and a well set up suspension wise car will make you quicker point to point regardless of what power you have under the bonnet.
    To give you an example my sisters boyfriend has a 2lt Nova with no brakes or suspension upgrades just engine and gear box and my close friend used to have a Williams with brembos and full suspension upgrades - shock springs, roll bars, geo setup for his style of driving. At brands hatch while at the start the nova was pulling a good lead away having to brake early and take a slightly slower line the Williams caught up, once the Williams passed him and was pressing on the Nova was no where to be seen after about 5 laps and it was fast in a straight line but straight line only (went in it once, never again, not safe at all).
    I agree to a degree that a remap will/is better power v price but if you cant stop the thing adequately and it wollows all over the place when pressing on does not make it an enjoyable drive in my opinion.
    My 50 pence worth.
    Chris.
  27. Eyeball Paul
    Thanks for all the input guys but.....
    I dont want to sound off with people but what is the problem with the std brake set up, i dont want to give my job details away but i do drive fast cars at very fast speeds for a living and my 50p's worth is that the brakes on my S3 are more than up to the job, i have 15 years of driving and i really dont see them as a problem, shocks and springs i can understand but not the brakes ???
    What are other peoples views on this as im interested ! brakes are very important and play a big part in going quicker but why fix something that is not broken, am i just a lucky one who has ended up with a good set up that works perfect out of a set that as a norm are **** ??? or does my driving skills need looking at and my boss needs to think about getting someone else lol !!!
  28. Ess_Three
    5,383
    14
    You can overheat and fade standard S3 stuff in under an hour of hard road driving on challenging roads.
    I managed to overheat the pads and boil the fluid in a matter of months when my S3 was new...heaven knows how bad some of them are now with 8 year old callipers!
    Remove the inner dirt shields to let more air in, change the pads to something better and maybe fit some grooved discs and possibly change the fluid and you can improve them a lot...
    But you can still have them go mushy after a good few hours of playing.
    Fit Brembos - or a similar 4 pot set up - and you'll probably never fade them on the road - I couldn't....but you still can on the track.
    Fit some decent pads to the 4 pots (Ferodo DS2500s for example) and you are unlikely to have brake issues ever again.
    I'm not alone in finding the brakes poor...
    Even assuming they work, they don't offer much feedback...and the modulation isn't great.
    After driving an S3 with a 4 pot set up, you can brake later, harder, better gauge the grip and relax knowing that 'oh sh*t' feeling isn't going to come.
    Horses for courses...
  29. Westy
    Westy Well-Known Member
    17,443
    1,103
    My view is that the standard brake setup is not good after a remap. On the road driving sensibly as one should, they are ok. On a track pushing the car hard, they are dangerous.
    If you dont do track days I would say just get some decent discs/pads and braded hoses. If you will do track days get 4 pots.
  30. Essflee
    2,143
    67
    Makes me wonder how hard some of you lads drive on the public roads, don't get me wrong I'm no miss daisy but I really can't see the brakes are that bad unless your constantly hard on them like you would be on a track...
  31. Ess_Three
    5,383
    14
    The fact that I got through 3 sets of tyres (1 x 17" set and 2 x 18" set) and 3 sets of brakes (standard, uprated and Brembos) in 3 1/2 years and 13500 miles should tell you all you need to know.
    Drive it hard...and you need better brakes.
  32. Essflee
    2,143
    67
    You went through that lot in 13500 miles...ouch
    You did track days though didn't you ?
    If visiting track days on a regular basis then I could see that and I agree brakes and suspension would be a must, if the original poster (sorry can't remember his name) is only going to be using his car on the road as by the sounds of it he already has a real track car then I don't think an uprated break set up is vital...
