TTS coolant issue - head gasket?
sionie1 Mar 1, 2013
  1. sionie1
    sionie1 New Member
    26
    Our 58 plate tts roadster with 18k has been losing coolant at a rate of knots. Approx 5 litres in the past 2 weeks, on a daily round trip of 14 miles. Our local indie did a compression test and diagnosed a knackered head gasket. We contacted Audi, who have taken the car to the local stealers.. And the fun has begun!
    The audi technician is saying its not the head gasket, it's something else. What that something is is yet to be confirmed.
    can anyone suggest anything else it's likely to be. Something that causes the coolant loss, into the exhaust system, where it evaporates in clouds of steam.. I'm at my wits end now, with 2 completely different diagnosis.
  2. NHN
    29,351
    1,720
    Does it have any issues starting?
  3. sionie1
    sionie1 New Member
    26
    Starts fine.
  4. sionie1
    sionie1 New Member
    26
    The coolant warning light has been coming on, hence us being alerted to the issue. The indie initially said there's no way it's the head gasket, too low mileage, and too new a car.. He says he was shocked.
  5. NHN
    29,351
    1,720
    If it was leaking internally you would possibly see mustard & also bad starting, externally it would be fairly obvious at that rate.
    So I'd go with hose or rad leaks, but your guy has done a pressure test on coolant system huh.
    Did he use the pressure unit on the coolant reservoir to test?
    Any part can go wrong at anytime, no matter what age.
  6. gen.heinz guderian
    gen.heinz guderian Well-Known Member
    1,346
    126
    Gearbox oil cooler?
  7. sionie1
    sionie1 New Member
    26
    if I'm honest I don't know which test he did.. I'm going back in the morning to ask, before I head off to the Audi dealer.
  8. sionie1
    sionie1 New Member
    26
    Would this explain the coolant entering the exhaust system? The indie refilled the coolant and left it in the workshop overnight, no leaks...
  9. sionie1
    sionie1 New Member
    26
    Have found out that the indie ran a co2 test, which showed up that co2 was in the coolant system...
  10. NHN
    29,351
    1,720
    Urm if thats the case its very likely then yes, but I would to be sure stick a pressure unit on the coolant reservoir upto 1bar or so & leave overnight, see if its loses pressure, then you should see any external leaks, if none & its dropped then it must be head gasket or head.
  11. sionie1
    sionie1 New Member
    26
    Cheers. Will get onto the dealers on Monday .
