TTE950+ RS4, S4 B5 Upgrade Performance Turbochargers
TTE Si Jul 27, 2016
  1. TTE Si
    TTE Si Site Sponsor Site Sponsor
    1,580
    879
    TTE950+ RS4, S4 B5 Upgrade Turbochargers
    Our biggest power solution for the AUDI 2.7T V6 Powerplant aimed and designed for the power elite B5 owners like Philipp Kaess with the infamous RS4 Limo that holds multiple records for the B5 platform. A Huge amount of development tuning this turbo spec to create ultimate high power with good boost response.
    Engineered & Enhanced
    TTE950+ Turbochargers are based on Genuine BorgWarner Porsche K16 turbine housings and cores with Genuine BorgWarner compressor covers with TTE billet anti-surge inlets.
    TTE CNC machine in-house the Genuine BorgWarner compressor cover to allow fitment and maintain the efficiency of a larger highly advanced billet milled 7+7 blade high-pressure compressor wheel and for fitting the TTE billet Anti-surge 63.5mm inlets.
    The Compressor wheel is a TTE 7 blade billet milled high-pressure anti-surge geometry compressor wheel, features promote greater airflow and pressure using a low inertia wheel that performs like a wheel of even greater size and mass. 7+7 Blade technology enables lower boost threshold giving the user faster spool-up at lower engine speeds while providing the high boost with much less heat for powerful top-end performance.
    The K16 exhaust turbine housings are CNC milled in-house to allow fitment of the larger K24 turbine to an optimum clearance for maximum efficiency. We also modify exhaust entry port from a stock size diameter, increasing the size of the throat to increase the flow capacity before the turbine and perform other modifications after the turbine for increased performance.
    Turbine and shaft being BorgWarner (Porsche) K24 items. K24 turbine is clipped at BorgWarner. Clipping reduces the blade area thus increasing gas flow and so reduce backpressure and lowering exhaust gas temperatures, allowing safer higher boost levels. This clipping also gives a secondary advantage of removing some material, lightening the turbine thus reducing the rotational mass improving moment of inertia and spool.
    Genuine BorgWarner motorsport 360 deg journal bearing system are fitted, to remain durable at higher loads with no loss in transient response.
    Actuators used are uprated sprung OE units fitted with our reinforced clamps for trouble free operation. These also can also be modified/set to customer needs and specifications. These are supplied in kit form to allow the end user to custom fit as required.
    Equilibrium
    Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in-house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document.
    Key Points
    Genuine BorgWarner compressor housings with Billet TTE anti-surge 63.5mm inlets (Viton O-Ring seals inc)
    Genuine BorgWarner K16 exhaust housings, Ported & Modified for greater gas flow
    TTE Latest Billet Highly Efficient Next Gen compressor geometry
    Genuine BorgWarner K24 Turbine, Clipped & lightened
    Genuine BorgWarner Reinforced Motorsport bearing system
    Genuine BorgWarner Modified reinforced and synchronised actuators supplied in kit form for custom fitment
    Single parts finely balanced then components assembled and high-speed VSR balancedURL]
    Supplied with a serial numbered balance test document for each turbocharger
    1080PS proven on e85
    Brand new Price is 4536.97 Euro net
    (For customers in EU countries 19%+ VAT Must be added to prices above unless have a valid VAT ID)
    Shipping does vary but 45.00 euro is a good guide for Europe-wide.
    ATTENTION:
    These turbochargers need custom installation are not Plug & Play. We can provide at extra cost THE-TUNER manifolds and intakes if required and downpipes.
    Hovde likes this.
  2. TTE Si
    1,580
    879
    Hovde likes this.
  3. TTE Si
    1,580
    879
  4. TTE Si
    1,580
    879
  5. GMballistic
    GMballistic Active Member Team Brilliant Black Audi S3
    174
    114
    43
    Incredible. :sunglasses:
    TTE Si likes this.
  6. TTE Si
    1,580
    879
  7. TTE Si
    1,580
    879
    The notorious RS4 TTE950+ Limo of Hannover Hardcore pulling deep into the 300+ Kmh zone.
    Shot taken from JTmedia.fi youtube video :
    Hovde likes this.
  8. TTE Si
    1,580
    879
    ULTIMATE B5 STARTER KT
    THE-Tuner TTE950+ kit
    Hovde likes this.
  9. TTE Si
    1,580
    879
    AUDI S4 B5 TTE950 1/4 Mile 2016 10,5s 221 Kmh
    Hovde likes this.
  10. TTE Si
    1,580
    879
    Philipp of Hannover Hardcore Audi S4 B5 3.0 TTE950+ Running a 10.19 Sec 1/4 mile @149.12MPH and with a slipping clutch in 4th gear.
    Hovde likes this.
  11. TTE Si
    1,580
    879
  12. TTE Si
    1,580
    879
    TUNETEC PROJECT 1 xxx ps complete!
    THE VEHICLE GOT 2 mappings during the trip switchable:
    1 Level 857 PS / 978 NM LD 2,1 @ 1,9 bar
    2 Level 1013 PS / 1156 NM LD 2,6 @ 2,4 bar
    Engine design and software by TUNETEC , mechanical implementation took place by my werkstattpartner Bernhard Reitsamer e.U., at this point again my sincere thanks for the implementation and completion of the vehicle after a long odyssey in "Just 3 weeks" - top performance berni [​IMG](y)
    Rough list of built components:
    - loader TTE950+
    - exhaust manifold the-tuner
    - intake pipes the-tuner
    - Nozzles 1450 CC E-100 fit
    - system 3,8 bar
    - 3 x pierburg e3l
    - Catchtank
    - enlarged benzinleitung before and back
    - Fuel E-80
    - Wmi-Boost Cooler with 2 Nozzles
    - 3.0 l block
    - rec piston
    - Rec rods
    - Compression 8,2: 1
    - camshafts suction
    - Suction Heads
    - reinforced ventilfedern
    - modified valves
    - DK Rs4
    - and-Rohr series
    - Llk the tuner
    - wagner intercoolers
    - Hfm Case 95 mm
    - trousers pipes 70 mm
    - Exhaust System 76 mm from Kat to 90 mm wilke
    - gearbox reinforced
    The vehicle comes back to us in the spring of 2018 to get another upgrade, which will include the following parts:
    - CNC milled heads of ng motorsport
    - modified camshafts
    - DK Rs6
    - the tuner pipes
    - the tuner inlet bridge
    - the tuner y-tube
    We're excited to see how much performance is on top of it.... stay tuned [​IMG]
