TTE800 Upgrade Turbochargers 4.0TFSI RS6/RS7/S8/S7/S6
TTE Si Jan 18, 2016
  1. TTE Si
    TTE Si Site Sponsor Site Sponsor
    1,603
    888
    TTE800 is our first hybrid performance upgrade turbocharger step for the 4.0 TFSI. Even more power, with great response as a stock turbocharger but with durability for higher boost
    Engineered & Enhanced
    To construct a pair of TTE800's we change the original compressor and employ a far larger and more efficient billet wheel with extended tip technology and mill the compressor cover to optimum gap to match the new compressor profile.
    We install a clipped turbine for greater gas flow. The clipping of the turbine is a special TTE grinding process to the turbine blade tips. Curved to alleviate stress from process. Clipping reduces blade area thus increasing gas flow and so reducing back pressure and lowering exhaust gas temperatures, allowing safer higher boost level. This process also gives a secondary advantage of removing some material, lightening the turbine thus reducing rotational mass improving moment of inertia.
    Equilibrium
    Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document.
    Key Points :
    Latest billet compressor geometry
    Genuine IHI CNC modified housings
    Genuine IHI turbine/shaft, Clipped & lightened
    Optimized clearances
    Single parts finely balanced then assembled and balanced
    Core high-speed VSR balanced
    Each turbo Supplied with test result document
    We offer brand new or we also can offer to recondition and upgrade your used turbocharger
    Brand new Price is 6721.85 Euro net
    Reconditioned and upgraded used Price is 2520.17 Euro net (Based from a supplied used good condition turbos)
    Shipping does vary but 80.00 euro is a good guide for Europe wide.
    (For customers in EU countries 19%+ VAT Must be added to prices above unless have a valid VAT ID)
    (Pictures bellow are of recon/upgrades)
    Dyno of STOCK RS6 vs TTE800 RS6
    racerboy55, THQuattro and MartayMcFly like this.
  2. bqik
    bqik Active Member
    134
    75
    Hello,
    As I see in your post you say that this is also for S8.
    The S8 restyling engine is the same of the RS6 or the S6 ( internals)?
    The S8 has the same tiptronic as the RS6 but don't know if they share also the engine.
    TTE Si likes this.
  3. TTE Si
    1,603
    888
  4. Ping9935
    Ping9935 New Member
    Hi, how much to record my current 2014 Audi rs7 turbo to TTE800? The prices that you list is it for a pair?Located in Malaysia postcode:88450
    Currently owned a 2014 Audi RS7 with APR stage 2 with milltek full exhaust(car deleted).
    Looking to get some more power from this 4.0 motor, so would like to upgrade turbos.
    Here's the question,
    1- Does APR support this turbo kits? (As in website, it says oem fitment. So does it mean just plug and play without doing any tunes on it. )
    2- does this turbo required an upgraded intercooler, oil cooler and transmission cooler?
    IanP19 likes this.
  5. TTE Si
    1,603
    888
    Yeah prices are for a pair and prices are shown above.
    Shipping to your location would be approx 350/400 euro insured air express
    APR does not have a tune for these but does for our larger TTE9XX. But really I don't advertise or actively market as we feel the original charge cooler is a major restriction and limts the potential and so you get lag without power. Until there's a upgrade option or replacement for air to air I feel not right to advertise.
    TTE800 is only a small step over stock but it's proven worthy again using the stock charge cooler.
    Plug & play means fits like stock (are stock modded units)
    Oil cooler and transmission I don't know of any partners doing.
  6. Ping9935
    Ping9935 New Member
    Possible to install the compressor by ourself TTE800? Does it need a new tune for it?
  7. TTE Si
    1,603
    888
    Hi,
    No of course not. The Compressor wheels are bigger, so the compressor housing needs CNC machining to suit and yes need specific software to allow for the extra air mass flowing into the engine.
    Rumpelkillskins likes this.
  8. Ping9935
    Ping9935 New Member
    Merry Christmas and Happy New Year guys,
    So before I proceed with the turbo upgrade purchase, who's the tuner that can do the tuning for me while I'm in Malaysia? Does the tuning has different maps for different fuel selection (98,104,108,or 112)??
    Could you please directly PM me so we can sort everything by then.
    Email: pgwong2004@yahoo.com
    TTE Si likes this.
  9. TTE Si
    1,603
    888
    PP-Performance software id say for your region?
  10. TTE Si
    1,603
    888
    Nice results in china and New 2017 entry on to our owners leaderboard.
    Ricky Cham drops into 3rd place within the 1/4mile category in a AUDI RS6 C7 TTE800 using PP-Performance software
    10.48sec @132.04 MPH
    Full weight, road tyres, 98 fuel
    Told new mods planned and tweaked software so will go faster !
    Waiting on the PBOX dnb data so can get the car onto the 100-200 leader board but 6.6 screen shot is a nice indicator
  11. TTE Si
    1,603
    888
    Audi s8 plus 4.0 tfsi with a series of 605 PS / 750 NM
    TTE800 Upgrade turbos
    Capristo exhaust
    MCCHIP-DKR Stage 3 software
    789 PS / 927 NM
    (stock intakes and airbox, stock charge cooler)
    Horia, racerboy55 and Tuddie like this.
  12. Roar Stegegjerdet
    Roar Stegegjerdet Rotrax
    91
    17
    Does the TTE9xx need custom inlet pipes?
  13. TTE Si
    1,603
    888
    Both TTE800 & TTE900 benefit from larger inlets as the compressor inlets on the turbochargers are a bigger diameter. MRC Tuning sell carbon inlets to match
  14. TTE Si
    1,603
    888
    Horia likes this.
  15. Roar Stegegjerdet
    91
    17
    Oky, so we do not need it? But its good to change. What will the typically cost? Sterman have some for 2500 dollar
  16. TTE Si
    1,603
    888
    id say yes is needed. Speak to MRC on those as not my part or do i sell.
