TTE780+ Upgrade Performance Turbochargers RS4 / S4 B5 / A6 2.7t
TTE Si Jan 6, 2015
  1. TTE Si
    TTE Si Site Sponsor Site Sponsor
    1,661
    934
    TTE780+ Upgrade Turbochargers RS4 / S4 B5 / A6 2.7t
    Welcome to our Ultimate level for the 2.7 T motor, using RS6 exhaust turbine housings. Developed from our 750 series. These are maybe the pinnacle of RS4/RS6 type hybrids offered anywhere for response and also power. 780PS capable on 102 RON and up to 900PS on E85 fuel has been achieved by S-Performance.
    Engineered & Enhanced
    TTE780+ Turbochargers start life as Genuine RS6 K04 OE units. Engineered and enhanced using in most part BorgWarner components or better. These units offer our fifth turbocharger step to increasing your 2.7T motor performance, yet offer relative little loss in response for such huge power potential. Offering a balance of high power and fast response. Making around 2.0bar at 4k rpm on a 2.7 motor with right hardware and tuning.
    TTE780+ has RS4 compressor covers with larger TTE CNC billet inlets that we CNC machine in house to an optimum clearance to allow fitment and maintain the efficiency of a larger highly advanced billet milled 7+7 blade high-pressure compressor wheel. This billet compressor also has a very high efficiency. We also give these compressor cover outlets some extra attention porting and polishing the boost discharge outlet to smooth the airflow to the boost pipework for improving efficiency.
    The Compressor wheel being a 7 blade billet milled high-pressure anti-surge geometry compressor wheel, features promote greater airflow and pressure using a low inertia wheel that performs like a wheel of even greater size and mass. 7+7 Blade technology enables lower boost threshold giving the user faster spool-up at lower engine speeds while providing the high boost with much less heat for powerful top-end performance.
    The RS6 exhaust turbine housings are CNC milled in-house to allow fitment of a far larger turbine to an optimum clearance for maximum efficiency. We also CNC modify exhaust entry port from a stock size diameter of approx 38mm to new TTE size of 44mm and tapering, so increasing the size of the throat to increase the flow capacity before the turbine.
    Turbine and shaft being BorgWarner (Porsche) K16 items, measuring with a 49.1mm Exducer and with a 55mm Inducer, compared to RS6 K04 with an Exducer 44.4mm & 50mm Inducer that we use on our smaller stages. We also give the K16 turbine a clip. Clipping reduces the blade area thus increasing gas flow and so reduce backpressure and lowering exhaust gas temperatures, allowing safer higher boost level's. Curving the clip is to alleviate stress from the process. This clipping also gives a secondary advantage of removing some material, lightening the turbine thus reducing the rotational mass improving moment of inertia and spool.
    Special profile 360 deg TTE developed high-performance motorsport journal bearing system are fitted, to remain durable at higher loads with no loss in transient response.
    Actuators used are uprated sprung OE units fitted with our reinforced clamps for trouble free operation. These also can also be modified/set to customer needs and specifications.
    Equilibrium
    Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in-house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document.
    Key Points
    Genuine BorgWarner RS4 compressor housings and key components
    Ported discharge outlets and compressor cover coated in Hi-Temp black paint
    Genuine BorgWarner RS6 exhaust housings CNC ported & modified
    TTE Latest Billet compressor geometry
    Genuine BorgWarner K16 Turbine, Special Curved Clipped & lightened
    TTE Reinforced Motorsport bearing system
    Genuine BorgWarner Modified reinforced and synchronised actuators, coated in Hi-Temp red paint
    TTE CNC Billet 58mm inlets (Viton O-Ring seals inc)
    Single parts finely balanced then components assembled and high-speed VSR balanced
    Supplied with a serial numbered balance test document for each turbocharger
    Installation as original RS4 K04 (with regard to oil and water line, all else see bellow)
    780PS Capable
    Brand New Price 4284.87 Euro net
    To Recondition and upgrade a used set of RS6 K04 to TTE780+ Price is 2604.20 Euro net
    Shipping does vary but 45.00 euro is a good guide for Europe-wide.
    (For customers in EU countries 19%+ VAT Must be added to prices above unless having a valid VAT ID)
    Reconditioning price shown is based on overhauling and reconditioning, upgrading an undamaged used turbochargers within specification. Only once cleaned and dismantled, inspected then a firm price be made
    ATTENTION
    These turbochargers use K04 RS4 B5 compressor housings with 58mm inlets. Specific turbo intake pipes to suit are required. The turbine housings are RS6 C5 specific, so flange on downpipe is needed to match. They do not work with RS4 B5 specific downpipes but these can be adapted with use of a RS6 flange.
    Optional Performance Extras
    Extra Lightened Turbine shafts (Please email for pricing)
  2. TTE Si
    1,661
    934
  3. TTE Si
    1,661
    934
    Congratulations to S-Performance for taking part at speeddays / kings of Germany 2015 yesterday in their S4 3.0 Powered by TTE780 Upgrade turbochargers.
    Maybe fastest S4 B5 in the world on RS4/RS6 Hybrids !
    1/4 mile 10.7sec@217,52Km/h (135.161 MPH)
    Car weight 1785Kg with driver
    Hovde likes this.
  4. TTE Si
    1,661
    934
  5. TTE Si
    1,661
    934
  6. TTE Si
    1,661
    934
    RS4 3.0L TTE780+ Turbos software by TUNETEC
    S4 TTE780 2.9L E85 Fuel
    Gives a idea of response from K16 turbine
    Hovde likes this.
  7. TTE Si
    1,661
    934
  8. TTE Si
    1,661
    934
  9. TTE Si
    1,661
    934
    Little comparison compiled by M100 Software engineering
    Hovde likes this.
  10. TTE Si
    1,661
    934
    RS4 3.0 TTE780+ M100 Software
    Moderate 2.1 - 2.0 Bar (no wmi) 737PS 973Nm
    And for the haters where is the Lag...Around 600Nm at 3000 Rpm :thumbup:
    Hovde likes this.
  11. Miguel_S#
    Miguel_S# Active Member
    337
    29
    did you try this setup with the new 2871x compressor?
  12. TTE Si
    1,661
    934
    Yes we have a set on our company rs6 4.2 v8 (like twin TTE420)
    Hovde likes this.
  13. Miguel_S#
    337
    29
    cool
    did you test in a 2.7 engine?
  14. TTE Si
    1,661
    934
  15. s3_trev
    s3_trev Northern Ireland Team Brill Red Gold Supporter Audi S3
    1,859
    638
    Great writeup and full of detail
    TTE Si likes this.
  16. TTE Si
    1,661
    934
    TTE TECH.
    Close up detail of the CNC porting on RS4 / S4 B5 TTE780 exhaust entry port.
    This TTE performance option can be added to TTE600 & TTE700 at extra cost
  17. Miguel_S#
    337
    29
    what is the bore diammeter after cnc porting?
  18. TTE Si
    1,661
    934
  19. TTE Si
    1,661
    934
    RS4 B5 3.0 TTE780
    2.0 bar boost flat 738PS 915Nm (boost limited for organic clutch)
    Hovde likes this.
  20. TTE Si
    1,661
    934
    TUNETEC RS4 3.0 TTE780 768PS 1006.3Nm 102 Fuel, 2.1bar - 1.55bar
    Hovde likes this.
  21. TTE Si
    1,661
    934
  22. TTE Si
    1,661
    934
    Here is some incar screen shots for spool/boost on a TTE780 2.7 RS4 :thumbup:
    4th gear
    5th gear
    Hovde likes this.
  23. TTE Si
    1,661
    934
    KSF Motorsport S4 3.0 TTE780 98 fuel + wmi @2.01 bar MRC tuning software
    762.8ps 837nm (660@wheels)
    Hovde likes this.
  24. TTE Si
    1,661
    934
    Audi S4 WB 2.7 TTE780 by MRC Tuning
    675ps and 829nm on 95 ron fuel
    741ps and 949nm on 99 ron fuel
    Hovde likes this.
  25. THQuattro
    THQuattro Site Sponsor Site Sponsor Team Avus Silver Team V8 Team V6 VCDS Map User Gold Supporter Team Panther Team Silver Audi RS4 saloon Audi S4 Audi A4 quattro Audi Cabriolet Owner Group S-line owners group Manual
    1,822
    1,203
    That is such a lovely car
    TTE Si likes this.
  26. TTE Si
    1,661
    934
    Really is and owner is cool guy also
    Hovde likes this.
  27. TTE Si
    1,661
    934
  28. TTE Si
    1,661
    934
    S4 B5 TTE780 2.7 741ps 949nm on 99 ron fuel, MRC TUNING
    Hovde likes this.
  29. TTE Si
    1,661
    934
  30. TTE Si
    1,661
    934
    Nice easy boost high power set up
    SIDMOTORSPORT S4 WB 3.0 TTE780
    1.6Bar boost 690hp 815nm, Shell Vpower fuel
    Hovde likes this.
  31. TTE Si
    1,661
    934
    RS4 b5 3.0 TTE780s TUNETEC Software
    868PS 1052Nm (Limited could of made another 50ps or so)
    Hovde and THQuattro like this.
  32. TTE Si
    1,661
    934
    MB-Tuning RS4 B5 3.0 TTE780 tuned by M100 - Software Engineering
    756PS 945Nm (appox 700Nm at 3.5k RPM)
    Hovde likes this.
  33. TTE Si
    1,661
    934
    This shows great turbo boost response of TTE780 turbos on Andre's 3.0 RS4
    3400 rpm 2.1 bar boost pressure
    Hovde likes this.
  34. TTE Si
    1,661
    934
  35. TTE Si
    1,661
    934
  36. TTE Si
    1,661
    934
  37. TTE Si
    1,661
    934
    Boost log kindly shared by Kemal Mocke
    Direct comparison of a rs4 b5 2.7 (9.0-1 CR) on stock RS6 turbos vs TTE780
    Same engine, same road, same near conditions and same fuel.
    As you see it backs up my telling all spool is great and not laggy at all. Reinforces why we dropped TTE700..
    TTE780 does it all !!! #BIGPOWERFASTRESPONSE
    Hovde likes this.
  38. TTE Si
    1,661
    934
    Mb-Tuning Audi Rs4 2.7 Project 700
    TTE780+ Turbochargers & M100 - Software Engineering LC+ NLS + MapSwitch
    Program 1 = 542 PS / 618 NM at 1,0 bar
    Program 2 = 709 PS / 833 NM at 1,7 bar
  39. THQuattro
    1,822
    1,203
    Luv it, great car.
    Good to have two maps.
    TTE Si likes this.
  40. TTE Si
    1,661
    934
    Agree with is a nice function
    Hovde likes this.
