TTE470 Performance Upgrade Turbocharger GOLF R GTI MK 7/S1/S3 8V/ TTS/CUPRA & SC 5F / OCTAVIA VRS
TTE Si Jan 13, 2015
  1. TTE Si
    TTE Si Site Sponsor Site Sponsor
    1,580
    879
    VW GOLF R & GTI MK 7 / AUDI S1 / AUDI TTS / AUDI S3 8V / AUDI Q S3 / LEON CUPRA & SC 5F / SKODA OCTAVIA vRS 5E / SKODA SUPERB SPORTLINE
    TTE470 is our hybrid performance upgrade turbocharger for the new 3rd generation VAG 2.0TSI following on from our proven TTE400+ upgrade stage. Fast boost response near like as a stock turbocharger but with durability and higher power.
    Engineered & Enhanced
    To construct a TTE470 we change the original compressor and employ a far larger and more efficient billet wheel with extended tip technology and mill the compressor cover to optimum gap to match the new compressor profile. We CNC modify original compressor cover and delete the DV function and port right before the compressor wheel to improve efficiency and power for increased airflow and CNC modify the compressor cover to vent to the atmosphere.
    We also fit our TTE CNC silencer delete. Modifying the turbo discharge silencer, removing the baffle internals and fitting a new straight through section, removing any restriction and its function as a noise cancelling device, and so improving the flow, giving less surge and enhancing the sound.
    We install a clipped turbine for greater gas flow. The clipping of the turbine is a special TTE grinding process to the turbine blade tips. Curved to alleviate stress from the process. Clipping reduces blade area thus increasing gas flow and so reducing backpressure and lowering exhaust gas temperatures, allowing safer higher boost level. This process also gives a secondary advantage of removing some material, lightening the turbine thus reducing the rotational mass improving moment of inertia.
    Equilibrium
    Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in-house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document.
    Key Points
    • Latest billet compressor geometry
    • Genuine IHI turbine/shaft, Clipped
    • Genuine IHI CNC modified housings
    • Genuine VW Electronic actuator
    • Genuine VW Recirc valve
    • TTE CNC Optimized modified silencer discharge delete
    • TTE Oversize Turbo Intake
    • TTE CNC Machined BOV
    • Optimized clearances
    • Plug & Play installation
    • Single parts finely balanced then components assembled and core high-speed VSR balanced, supplied with a balance test result document
    • We offer brand new or we also can offer to recondition and upgrade your used turbocharger
    • 470PS+ Capable and proven
    • Designed, Machined & Built by TTE in Germany
    Brand new Price is 2352.10 Euro NET
    Reconditioned and upgraded used Price is 1259.66 Euro NET (from IS38 used turbo )
    Shipping does vary but 45.00 euro is a good guide for Europe-wide.
    (For customers in EU countries 19%+ VAT Must be added to prices above unless having a valid VAT ID)
    Reconditioning price shown is based on overhauling and reconditioning, upgrading an undamaged used as new turbocharger within specification. Only once cleaned and dismantled, inspected then a firm price be made.
    Dandanfings likes this.
  2. Rogier140
    Rogier140 Active Member Team Sepang
    167
    72
    Hi Simon,
    Are there any testresults availeble ?
    Like dyno run and pk an nm results, torque curve ...
    Regards,
    Rogier
  3. TTE Si
    1,580
    879
    Here is one dyno from TIJ POWER
    Seat Leon R
    Car had all bolt on's
    Boost 1.6bar peak
  4. Rogier140
    167
    72
    okay so no 450+ pk ...
  5. TTE Si
    1,580
    879
  6. Rogier140
    167
    72
    :) Yeah , but for only 30pk more the cost is to high ...
    If it goes up to 450+ it will be a better investment
  7. Rogier140
    167
    72
    do you know the rest of the setup of the seat ? i cannot find any more info on facebook
  8. TTE Si
    1,580
    879
    Yeah cost is quite high vs power as such but this is par for the coarse and all new generation turbo stages go this way. But also i need tell you this is not a easy upgrade of just a wheel..
    But once the tuners work out best hardware and best ecu calibration the power will come its just time. Seen it time and again over the years :thumbs up:
    Here is TIJ post, maybe ask there
  9. TTE Si
    1,580
    879
  10. TTE Si
    1,580
    879
    Maybe strongest GTI 7 In The World !
    Our friends at IS-Racing Share their GOLF GTI 7 TTE450+ Turbo result..
    442PS 508NM (Limited)
  11. TTE Si
    1,580
    879
    David Lee in his GOLF 7R TTE450+ MRC tuned was at Santapod this Sunday just past doing shakedown testing at lower boost,98 ron full weight, road tyres
    1/4 Mile 11.6175 @117.91
    @1.5bar 60ft times are all 1.7s so plenty more to come!
  12. 805mk7gti
    805mk7gti New Member
    Is that to the wheels or are they converting wheel horsepower to crank figures? Impressive either way!
  13. TTE Si
    1,580
    879
    Crank. Near most all european figures are crank as like manufacturer figures
  14. 805mk7gti
    Okay thanks! When running the tte450+ r turbo on a GTI do you guys swap the stock GTI electronic wastegate onto the R turbo since the R wastegate is different? Do you know if they are running a piggyback or flash tune? If so which piggyback or what flash? Thanks
  15. TTE Si
    1,580
    879
    We use the Golf r actuator on tte400+ and tte450+
    We recommend custom tune to suit right now.
  16. TTE Si
    1,580
    879
  17. TTE Si
    1,580
    879
    Milltek's GOLF R TTE470 Mrc Tuning software 0-60 mph
  18. TTE Si
    1,580
    879
    0-60MPH Full tank and 2 people
  19. TTE Si
    1,580
    879
    Milltek Sport Golf 7R
    TTE470 turbocharger, Full Milltek exhaust, VW Racing R600 Intake, Forge Intercooler, MRC Turbo Intake pipe and MRC Custom Remap. 99 Fuel (No wmi)
    It did 447ps and 560nm. With a 0-60 time of 3.2 seconds on the vbox.
    RO65ERS likes this.
  20. Rogier140
    167
    72
    I am verry impressed with the dyno of MRC tuning. How sure am i of simular results with my tuner ?
    The previous results of TIJ power are 426 pk instead of the 447 of MRC.
    447 would be worth considering, 426 not.
  21. TTE Si
    1,580
    879
    Yeah well is no guarantees of results. Much more to it then that.
  22. TTE Si
    1,580
    879
    Also another TIJ result this time on a cupra 280 431PS 532NM
  23. TTE Si
    1,580
    879
    David Lee's GOLF 7R TTE450+ By MRC Tuning 461PS 510Nm
  24. Rogier140
    167
    72
    this looks more like it !
  25. TTE Si
    1,580
    879
    your tuner took a tte470 some weeks ago.
    Expecting results soon
  26. Rogier140
    167
    72
    i know :) i am waiting on the first results ....
    did it come with your intake pipe ?
  27. Rogier140
    167
    72
    i want to combine with:
    DV+
    APR muffler delete
    Intake pipe
    VWR 600 intake (instead of current APR)
    Spullen throttle pipe
    TTE Si likes this.
  28. TTE Si
    1,580
    879
    Yeah was taken
  29. TTE Si
    1,580
    879
  30. Rogier140
    167
    72
    102 octane ?
  31. TTE Si
    1,580
    879
  32. Rogier140
    167
    72
  33. TTE Si
    1,580
    879
    Thanks for sharing the dyno. For info JD tell me was able to get over 450ps at higher boost levels. They tuned at 440 because car is still on stock intercooler and stock rear exhaust system. There result looks laggy too ?
  34. Rogier140
    167
    72
    yeah, but they also said that it needed high boost levels to get this far 2.0 bar for 440 pk.
    And that may is much and needs still to be proven to be reliable.
    I drive about 35.000 km a year so i need to be sure it can hold up.
  35. TTE Si
    1,580
    879
    Ok they tell you more info then me as I got no boost values from them after contacting when you shared the dyno.
    I told them MRC and David Lee make 460ps at 1.8-1.85 bar peak but with upgrade IC and full sports exhaust. Still much to learn for all on this platform.
  36. Rogier140
    167
    72
    I am still in doubt if this is the way to go for me.
    Maybe i will make a switch to a S4.
    Do you have an bolt on turbo for that platform ?
  37. TTE Si
    1,580
    879
    Only s4 that is turbocharged is the B5 and yes we have many for.
    Newer are supercharged and we dont do anything for. Are upgrade out there like pully kits so on.
  38. TTE Si
    1,580
    879
    Just got off phone with Mark @JDengineering and it was 1.8bar peak for 440hp on there car. Mark was really quite posative regarding results bearing in mind stock intercooler and exhaust and on 98 fuel
    VW GOLF 7 R TTE470 by JDEngineering
    Spec:
    TTE450+ Upgrade Turbo + TTE450+ intake pipe
    Milltek downpipe - 200 cells sportcat
    VW Racing intake
    JD Stage 3 remap
    JD MQB DQ250 DSG remap
    440pk & 540Nm
    98 fuel
    (Stock exhaust & Stock intercooler)
  39. Rogier140
    167
    72
    did you test the max bar capacity of the TTE setup?
  40. TTE Si
    1,580
    879
    David Lee in his GOLF R TTE450+ MRC was at santa pod yesterday..20 mph wind and issues with launch control but still a 11.3 second run !
