TTE280 Upgrade Performance Turbocharger AUDI A4 B5 /B6 1.8T 20V LONGITUDINAL
TTE Si Jan 6, 2015
  1. TTE Si
    TTE Si Site Sponsor Site Sponsor
    1,603
    888
    TTE280 Upgrade Turbocharger Longitudinal AUDI A4 B5 & B6 / PASSAT 1.8T
    Introducing our TTE280 performance turbocharger for the 1.8T VAG longitudinal platform.
    Engineered & Enhanced
    To produce our hybrid K04 TTE280 upgrade turbocharger we use a much larger BorgWarner 2283 billet compressor wheel, chosen because it is highly efficient and features BorgWarner Extended tip technology, creating extremely high flow for comparative size, but giving a compressor map that's very wide.
    The intake to the compressor wheel is CNC milled billet and hand polished to smooth the transition from the intake pipe work to the larger compressor to lower turbulence and maximize velocity. We CNC profile the billet intake and fit to the compressor cover and set to a optimized tolerance/gap to ensure maximum compressor efficiency is given.
    We CNC re-profile the exhaust turbine housing and port the exhaust outlet to accept a larger K04 turbine and shaft, a BorgWarner item, that we give a special curved clip of a specific amount. The clipping is a TTE grinding process to the turbine blade tips, curved to alleviate stress from process. Clipping reduces blade area, increasing gas flow and so reducing back pressure and lowering exhaust gas temperatures, allowing safer higher boost level's. This process also gives a secondary advantage of removing some material, lightening the turbine thus reducing rotational mass, improving moment of inertia.
    Special profile 360 deg high performance BorgWarner motorsport journal bearing is fitted, to remain durable at higher loads with no loss in transient response. Actuator used is uprated sprung BorgWarner unit. This also can also be modified to customer needs and specifications if needed.
    Equilibrium
    Precisely balancing our turbochargers is a key critical factor to become a TTE upgrade unit as longevity and performance are paramount. Good balance improves acoustics also. Subsequent great care is taken with all TTE turbochargers to achieving our balance standards. Firstly parts are balanced at slow speeds up to 2800RPM in multiple planes using our single parts machine, then components are assembled and then the CHRA are dynamically balanced, but this time depending on application at up to 250,000 RPM in multiple planes using our in house VSR machine to acquire the ultimate equilibrium, to a standard far higher than OEM. Each turbocharger is supplied with serial numbered balance test result document.
    Key Points
    Genuine BorgWarner modified housings
    Genuine BorgWarner Billet 6+6 extended tip compressor geometry (Inducer 46.50mm / Exducer 59.50mm)
    Genuine BorgWarner K04 Trim 8 enhanced output clipped turbine (Inducer 50mm / Exducer 44.50mm)
    TTE Billet 58mm oversize intake (Viton O-rings Seals inc)
    Genuine BorgWarner 360 ° Reinforced bearing system
    Genuine BorgWarner uprated actuator
    Optimized clearances
    Single parts finely balanced then components assembled and core high-speed VSR balanced, supplied with a balance test result document
    Fitment As Original with Supersize turbo intake pipe
    300PS Capable
    Brand new Price is 1343.70 Euro net
    Reconditioned and upgraded used Price is 797.48 Euro net
    Shipping does vary but 45.00 euro is a good guide for Europe wide.
    (For customers in EU countries 19%+ VAT Must be added to prices above unless have a valid VAT ID)
    Reconditioning price shown is based on overhauling and reconditioning, upgrading a undamaged used turbocharger within specification. Only once cleaned and dismantled, inspected then a firm price be made.
  2. Roots
    Roots Member
    89
    10
    Ive emailed you :)
    TTE Si likes this.
  3. TTE Si
    1,603
    888
    Nice result here for this A4 1.8T at 300ps 428Nm
    full spec
    Stock AEB motor - TTE280 Turbocharger - 3" exhaust system from turbo - 034 3" turbo intake hose - VR6 MAF housing - Highflow cast manifold - 380ccm injectors - 3bar fuel pressure regulator - Reinforced Sachs clutch - upgrade intercooler KWE - Software by GT performance 1.55BAR PEAK down to 1.2bar Vpower fuel (no wmi)
    rob martin likes this.
