TT wishbones
PH1L Apr 18, 2010
  1. PH1L
    PH1L Gievf Buckets
    3,851
    40
    I belive a while back people were fitting these to the front of s3's am i right?
    what is involved in it, ie what are the benifits and is the fit a direct swap, also if anyone has wishbones from thier s3 please speak up i may be interested in them
    cheers guys
    Phil
  2. s3mike
    s3mike Member
    240
    I thought this was more for A3's.
    I believe the S3 already has aluminium front wishbones and subframe whereas the A3 has steel - hence why the TT wishbones are an upgrade for A3.
  3. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i think they had camber adjustment as well im on the scrounge as one of mine needs replaced
  4. dunk
    dunk Member
    770
    its the tt fwd bottom arms - not because they are alloy (although every little helps, as a certain supermarket says) but because they give a lot more negative camber with some adjustment.
    i dont know if the s3 has the same adjustable and longer arms as the tt though
  5. PH1L
    PH1L Gievf Buckets
    3,851
    40
    cheers mate, i just got another s3 alloy one
