TT Window fault
Discussion in 'TT/TT-S/TT-RS Forum' started by pablocurrants, Jan 4, 2010.
  1. pablocurrants
    pablocurrants New Member
    Jan 4, 2010
    Hi
    I've got a '99 TT 225 and the passenger window does not seem to rise to its full height. It's only a matter of a couple of mm but it's causing a lot of wind noise at high speed. I'm guessing this is possibly a common fault. Does anyone know if it easily adjusted/repaired? And if so how!?
    Best regards
    P.
  2. Advert Guest Advertisement
  3. scoTTy
    scoTTy Active Member
    Jan 2, 2003
    1,962
    Press and hold the window down button until it's fully down and don't let go for a further 5 secs. Do the same in the up direction and then repeat down and up again.
    That should recalibrate it.
  4. Aussie tt
    Aussie tt If in doubt?? F L A T O U T
    Dec 5, 2009
  5. pablocurrants
    Jan 4, 2010
    Cheers scoTTy. Do I do the 5 second thingy on the 2nd time I put the window down and up?
    (Thanks again)
  6. physiojlb
    physiojlb New Member
    Jan 11, 2010
    hi,
    i have the same problem with my drivers door. i tried the window reset and it helped a little so will try again. i did all the way down all the way up and hold for 5 secs, hadnt done the hold down for 5 secs.
  7. T3RBO
    T3RBO 6th Gear
    Jan 17, 2003
    131
    Window reset
    ignition on
    windows all the way down
    windows all the way up, let go of switches
    push them up again and hold for 3-5 seconds
    ignition off
