TT-RS Brake Kit Fits S3?
mrgicm Nov 25, 2009
  1. gynads
    gynads Member
    314
    How much is the whole TT-RS conversion?
  2. smudge_don
    smudge_don Active Member
    2,944
    Depends where you go, but you're looking at about £1500
  3. Spin140
    Spin140 Well-Known Member
    2,196
    186
    TT shop charge £1,550 supply.
  4. N8
    17,163
    718
    I can get you it for about £1k.
  5. smudge_don
    2,944
    Getting mine fitted by TT shop very soon
  6. gaz m
    gaz m Member
    139
    As I said in our chat,
    You will not be dissapointed mate. There a great upgrade just remember to take some photo's!!!
    Gaz
  7. smudge_don
    2,944
    Cheers for your help Gaz :)
    I will get pics just for you :yes:
  8. smudge_don
    2,944
    Just secured my TTRS front brakes :happy:
  9. N8
    17,163
    718
    Well done Jords, car is coming along nicely.
  10. smudge_don
    2,944
    Just picked mine up, will be fitting them in the next couple of weeks
  11. akash_sky1
    akash_sky1 Active Member
    1,181
    foom me there massive! Your gonna loose a fair few WHP with those bad boys fitted
  12. smudge_don
    2,944
    370mm!
    Good thing i'm getting some performance mods soon then :)
  13. micasb
    micasb Member
    327
    Hi there people.
    I have that setup in my A3 8P 2.0 TDI. The setup is excelent. I have rear S3 brake system. Is there any kit apllyable to the A3 with better braking power for the rear?
    I've seen a user that got 355mm on the rear but with what calipers?!
    Regards.
  14. gaz m
    gaz m Member
    139
    Why would you want any more than the S3 brakes that you have on the rear of your car now?
    I had the TTRS set up on my S3 and thought it was a great improvment over standard, with great feel and bite to the brakes.
    In all honestly on a road car the rear brakes main job is to help keep the back end in a straight line whilst the fronts do about 70-75 % of the work I would say the combination of TTRS fronts and S3 rears is pretty much the perfect brake set up for a road going A3/S3 or even the odd track day car will benifit from this set up.
    Gaz m
  15. S3Alex
    10,697
    4,749
    You'd need to be very careful with this sort of thing.
    As has already been said,by massively increasing the size of the rear setup,you'll be shifting the brake balance quite markedly,and this in turn will influence the handling under heavy braking.
    As an example,I'm going to be changing the front setup on my S3 shortly,and was advised against fiddling with the rears for exactly that reason,and the same advice(from different engineers) was had for the braking setup on the GpN Escort Cosworth I used to have.
    You may not notice it under normal braking situations,but when you have the ends of the car trying to fight each other under heavy braking.....
  16. gaz m
    gaz m Member
    139
    Just one more thought on this micasb
    Have you thought about getting the upgraded Haldex controler as in sport mode it keeps the 4 wheel drive system active so you will have 4 wheel engine braking whilst you apply the brakes instead of front wheel only?
    This may give you the extra braking you want but will keep the correct brake ratio's front to rear so extra braking power but still nice and safe with no rear wheel lock ups!
    Gaz m
  17. mrgicm
    mrgicm Phantom black S3/
    137
    I have a 355mm 2 peace floating discs on the rear on the standard S3 rear callipers and its just perfect, fits just right...
  18. gaz m
    gaz m Member
    139
    What do you have on the front brakes mrgicm? Your combination of brakes may be a perfect match for what is fitted on your car which keep the ratio front to rear about right.
    We are just trying to advise micasb that if he get's the ratio wrong, as soon as he brakes for real he will lock up the back and probably head off the road!
    I still think the combination that he has is very good for the power of a modified S3 with out going to much more effort. Unless he goes for the Porsche set up as you have on the front of your car and then he can go for extra braking force on the rear.
    Strangly enough that is a similar set up to my car which I can say works very well no mater what silly speed I approch corners.
    Gaz M
  19. N8
    17,163
    718
    My 4 pot R8 fronts and S3 rears on mine are perfect, perfect pedal, no travel.
  20. mrgicm
    137
  21. micasb
    micasb Member
    327
    Hi people.
    I don't have an S3... LOL I have a FWD 2.0 TDI with TT-RS front brake system and S3 rear brake system.
    What i was asking is what discs an pads did you use for that 355mm setup in the rear end mrgicm?
    Do you guys think i'll have a unballanced braking if i go 355mm on the rear?
    Do they fit the rear S3 calipers?
  22. S3RYE
    S3RYE Interior Next!!
    3,448
    70
    thats some serious braking power... you highly tuned or just looks??
  23. micasb
    micasb Member
    327
    About 300 bhp... But i like to feel a real safe car... :p
    Sometimes i feel the rear a little "float" as mrgicm said...
    I think with those 355mm he has i could have the perfect breaking power along with the front system...
    Regards.
  24. S3RYE
    3,448
    70
    impressive mate :respekt:
  25. Dt_racing
    Dt_racing Active Member
    232
    117
    43
    Just to add to this thread as I'm sure some will be interested, I was when I was looking. The TT-RS setup also sits very nicely behind pre-facelift S3 alloys with a 12mm spacer...
  26. pluves1
    pluves1 Active Member
    725
    133
    43
    Are any spacers needed for the facelift 18" S3 alloys?
    Would spacers be needed with 19" genuine Audi Rotors?
  27. S3_Mat
    S3_Mat Active Member
    545
    187
    43
    Dt_racing Thanks very much for testing this! I was always put of this kit because of reports they did not fit under that wheel. I'm now trying to source OEM Discs for cheap and going ahead with this.
  28. S.
    S. Save the manuals Team Ibis TFSI Owners Group Audi S3 quattro Manual
    2,005
    545
    yes they are needed. you could be fine with 10mm spacers but i've gone for 12mm spacers.
    don't know for rotors. there's a thread with wheel fitment and ttrs brakes....
  29. Dt_racing
    232
    117
    43
    If you manage to find some OEM discs cheaper than the stealers let me know... been looking myself with no luck.
