TT magnetic ride
Gavin0478 Jan 4, 2012
  1. Gavin0478
    Gavin0478 Active Member Team Daytona Team V8 VCDS Map User quattro Audi Q7 S-line owners group TDi
    522
    39
    Hi looking for a little bit of knowledge from you guys...
    Looking at a new S3 (runs n hides) and thinking of spec'n the magnetic ride.
    Problem is its rare on an S3 but standard on some tt's.
    Is it a worth while feature but more importantly does it cause any issues if i lower the car.... can you remap the dampers so to speak to compensate etc?
    Cheers Gav
  2. warren_S5
    warren_S5 Moderator Staff Member Moderator VCDS Map User
    7,210
    2,486
    I think both H&R & Eibach do spring kits that are compatible with MR, but it may be worth speaking to Damian at DPM to confirm.
  3. Gavin0478
    522
    39
    Cheers chap i have dropped them a line.
  4. warren_S5
    7,210
    2,486
  5. Gavin0478
    522
    39
    id found that one but as its over 4 years ago id let it pass by lol
  6. S3DBW
    S3DBW Member
    180
    23
    Hi Gavin,
    Cant give you any advice re lowering, but my wife has the magnetic ride option on her S3. I actually find it very good, for the majority of running its left on the normal setting, but when you get a good section of twisting road and are in the mood to press on, the sport setting really firms up the suspension. It can be a bit jarring on really rough roads, but then you can always revert back to the softer setting. I would certainly add it to the spec list if I was planning a new one.
    cheers
