TT Caliper Carriers
Caesium Mar 6, 2007
  1. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    I understand it that you can fit these carriers and then 312mm discs onto the existing callipers and they will work, I'm going to do this soon as my discs are warped.
    Does anyone know where I can get the carriers from at a reasonable cost?
  2. arthurfuxake
    1,308
    Why not just put the 2.5TDi V6 180bhp carriers and discs on? They're 312mm.
  3. Seraph
    Seraph New Member
    2nd hands the best option - theyre something silly like £70+vat per side from VAG
  4. Caesium
    4,879
    The 2.5 tdi a4? I only need the carriers and discs not callipers. Any idea where to get them?
    Yup I know that, but where from? I was looking for suggestions
  5. bubstar
    bubstar Member
    550
    My 190 1.8t has 312mm discs fitted as standard too.
    I'll be upgrading mine soon.......... ;)
    BUB
  6. Caesium
    4,879
    do they have the same hub ie will they fit?!!
  7. james0808
    james0808 Active Member
    3,548
    I got some good second hand B5 S4 front brakes for £120.Twin piston calipers and 323mm discs.Look good with a bit of paint on and better han 312mm.
  8. arthurfuxake
    1,308
    Are they a direct fit or do they need an adapter?
  9. james0808
    3,548
    Direct fit.Dont even need to change the flexi pipes.Not sure what size wheels you need but they fitted behind my old 18's.
    Standard discs.
    Look much better with these.
  10. Caesium
    4,879
    If they'll fit on my b6 TDI then i'll have em!!
  11. Caesium
    4,879
    Anyone know where I can get a set of these from, are they readily available?
    I need to replace my discs soon as they are knackered and I'd rather get a set of better ones. All ideas welcome!
  12. phil1978
    phil1978 Member
    183
    I bought my carriers from VAGPARTS, from memory including delivery they were something like £110, unlike the £160'ish the stealers wanted. Just check you have the right splash shield etc. I have part numbers if you need any clarification.
    hope this helps
  13. james0808
    3,548
    I know a guy who is selling a front set up(no splash guards)off a B6 S4.345mm discs good pads and.He wants £200 for them,I would of had them for mine but im thinking about selling it.Dont know how much post will be as they are bloody heavy.
  14. james0808
    3,548
    calipers too.
  15. james0808
    3,548
    A4Quattro you have pm.
