TT/A3/S3 Front hubs/Shafts
mwstewart Jun 20, 2007
  1. mwstewart
    mwstewart Member
    199
    Hello everyone, are there any differences in the front hubs and shafts between the following cars:
    1.8T TT Quattro
    S3
    A3 Quattro
    Also, did the front hubs change between Quattro and FWD cars?
    Cheers,
    Mark
  2. HTC
    HTC Active Member
    3,428
    9
    I know for sure that the 4WD and FWD hubs are different.
  3. Lord Vader
    Lord Vader Member
    34
    Thats strange as the fronts on my car I identical to the rears, hubs that is!
    They use the same bearings and hubs on my 99 S3 front and rear, as I have just replaced the hubs and bearings.
  4. mwstewart
    mwstewart Member
    199
    Ahh sorry let me clarify, when I said hub I actually meant the whole unit; 'knuckle' is it?
    Thanks for the help so far.
  5. HTC
    HTC Active Member
    3,428
    9
    More specifics please. What are your plans?
  6. mwstewart
    mwstewart Member
    199
    It's for my project: http://www.mwstewart.co.uk/cars/fiestaquattro/
    I want to run 17" RS4 reps (new style), so I may as well use some Quattro hubs/knuckles rather than get some adapters machined to fit the wheels on to the Ford hubs.
    I'm just wondering when I go to the breakers, if I can get some from any A3/TT etc or whether I need O2M Quattro versions (if they're different).
    Cheers,
    Mark
  7. HTC
    HTC Active Member
    3,428
    9
    Nice project!
    Right, I'm with you now. FWD deffo different to 4WD.
    As for a3 quattro versus s3/tt quattro, I seem to rememeber them having different part numbers. S3/TT have a longer hub vertically to reposition the ball joint. This is to keep correct steering geometry for factory lower suspension.
    Can't rememeber if A3 quattro has this. I'll take a better look for you when I get in from work and have more time.
  8. mwstewart
    mwstewart Member
    199
    Cheers!
    Did you get chance to check the part numbers?
  9. HTC
    HTC Active Member
    3,428
    9
    Parts catalogue lists different numbers between Quattro and S3/TT Quattro.
    Driveshafts maybe slightly different lengths or at least a change of CV joint.
    I would go for the S3/TT parts exclusively for the ability of a lower car with more horizontal wishbones. Bound to be loads of dismantled TTs about.
    Hope that helps.
  10. nick-barnes07
    nick-barnes07 Member
    552
    hell of a project there , keep us updated how you get on , will be interesting to see the end result ,
  11. mwstewart
    mwstewart Member
    199
    Cheers for the comments.
    Many thanks for the help HTC, its very much appreciated.
