trying to understand
ch1z64
C'mon you's bhoy's in Green
Silver Supporter
Kilwinning Ayrshire
I have a few questions to ask the experts on here and hope they can give me advice so here goes ,
Firstly if you don't get a response back from a module would that be an indication that that module is not installed in your car .
Secondly I recently have had the wire loom installed ( bought from member on here ) and wondered if that could throw up the Haldex error code 00448
Thirdly and probably the hardest one to sort out and explain so please bear with me as I try to explain , I recently broke 2 wires which were in the B Blue block in my Rns-e one was the Brown bose wire and the 2nd was a Grey wire which was originally in the K-line pin ( if reading wire diagram ) then there was 2 other wires which are Yellow and Green ( can't mind were these where before I took them out as I was advised to move from Blue Block to 32 pin Av connector which I did but it was a crappy sound so just left these wires out off Blue Block ) So I recently moved the 3 wires Yellow Green and Grey back into B Block leaving 1,3,4,5,6,10,11,12 pins free , Grey went to 2 cdc NF Gnd yellow to 8 cdc NF L in and Green to 9 cdc NF R in. now I haven't done a scan again after doing this as I am hoping some one could possibly tell me where to put them . In the Green Block I have wires in pin 3,5,6,9,11,12. so leaving 1,2,4,7,8,10 empty , I don't have a A block
  • Log-DF59GUH-WAUZZZ8P5AA039310-150340km-93416mi.txt
  • Log-DG59 GUH-WAUZZZ8P5AA039310-151640km-94224mi.txt
Today i removed the 3 wires from 2, 9, 8 and placed them into Blue Block 3, 5, 10
I used this diagram for my RNS-E ...
Conn
Here is some of the color coding ...
Alfred
This post may help you ... http://www.audi-sport.net/xf/threads/help.186859/
this was todays one before i changed it around Mod 37 (0239757 ) after change it is ( 0235755 )
