TRW brake pad wear sensor pins wrong
Dimokslis Mar 30, 2014
  1. Dimokslis
    Dimokslis Member
    65
    Hi folks,
    Just installed new front brake pads yesterday and light on the dash did not go away, so went to check connectors today and found this.
    Picture - http://img834.imageshack.us/img834/1205/1vdpn.jpg
    Has anyone experienced that?
    Could be that if front brakes were LUCAS? As my ones are ATE and car connector pins are opposite to those on the brake pads.
    But I doubt that Audi changed pins just for different brake suppliers...
    Or its just TRW made it wrong???
  2. aragorn
    18,490
    855
    I'm not sure what your pic shows? the plug and connector look to match to me?
  3. Dimokslis
    Dimokslis Member
    65
    Look inside of the connector, pin1 and pin2 on the brake pad connector do not match with car connector's pin1 and pin2. Where on the old brake pad numbers matched with car connector's numbering and everything worked perfect.
  4. Bradderz_1988
    3,958
    240
    Pin layout shouldnt be a problem as your only closing the circuit, when the pads get low it becomes an open circuit thus bringing the light on, check the connection i no that my fronts are zip tied together as there a **** connection but there pagid pads and i had to do it with the mintex on the 312mm setup aswell !!
  5. aragorn
    18,490
    855
    As yes, i see now. As Bradderz says, its not a problem, as its just a loop of wire.
    I've just unplugged mine where it goes into the car, and shorted the wires.
  6. Dimokslis
    Dimokslis Member
    65
    Thanks, gonna have a look at it tomorrow, must be a fault in cars connector or harness.
    I really thought is more complicated inside of a wear sensor. :)
  7. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    376
    57
    Both my cars have thrown up fault codes on the brake pad sensor at one point or other. They get brittle with age when you're replacing pads, even trying to disconnect them is a black art! Check the pins aren't bent and fit snug. In addition the wiring isn't broken on the loom.
  8. Dimokslis
    Dimokslis Member
    65
    Well, I did not have a time (mood :?) to play with the wires and today light did not come back anymore. So hopefully it's all ok now. :)
    I did not know that its common problem with these cars, as my FL 1.9TDI PD never had any issues with it. I'll be aware now for the next time.
    Thanks everyone. :thumbsup:
