troubles coding Bluetooth module +rnse to a4 2007
@udi A3 May 5, 2013
  1. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,803
    192
    I've just tried to code Bluetooth module to an a4. I Dont have access to full logs right now as battery is flat but iirc it was coded to 0010310 or very similar, I wanted to code to 011822 or v similar
    The only digit I can code successfully is the second from last. All others say code rejected. There is one fault code which is communication with radio that won't stay gone. This doesn't affect the single digit being coded. Occasionally loading the 77 channel will result in blank coding until I restart .
    Any ideas?
  2. @udi A3
    1,803
    192
    Logs of 56 and 77
    Maybe i should be posting in retrofit as im thinking now after a little research the module may be non compatible.
    Saturday,04,May,2013,22:32:03:05185
    VCDS Version: Beta 12.10.3
    Data version: 20130228
    Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
    Control Module Part Number: 8E0 035 192 T HW: 8E0 035 192 T
    Component and/or Version: RNS-E HIGH EU H80 0650
    Software Coding: 0401757
    Work Shop Code: WSC 42684 126 82220
    VCID: 35619F1F5F5537B66C3
    4 Faults Found:
    00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
    007 - Short to Ground
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 223
    Time Indication: 0
    Date: 2013.05.04
    Time: 22:28:23
    Freeze Frame:
    Mileage: 655350 km
    Count: 405
    Clock: 22:28
    00878 - Connection to Speaker Front Left
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 223
    Time Indication: 0
    Date: 2013.05.04
    Time: 22:28:13
    00879 - Connection to Speaker Front Right
    011 - Open Circuit
    Freeze Frame:
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 223
    Time Indication: 0
    Date: 2013.05.04
    Time: 22:28:13
    00857 - CD Changer Unit (R41)
    004 - No Signal/Communication
    Freeze Frame:
    Fault Status: 01100100
    Fault Priority: 5
    Fault Frequency: 1
    Reset counter: 223
    Time Indication: 0
    Date: 2013.05.04
    Time: 22:29:03
    Saturday,04,May,2013,22:33:19:05185
    Address 77: Telephone Labels: 8P0-862-335.lbl
    Control Module Part Number: 8T0 862 335 E HW: 8T0 862 335 E
    Component and/or Version: FSE_256x BT H42 0650
    Software Coding: 0010320
    Work Shop Code: WSC 06325 000 00000
    VCID: 3C778A3B7C7FE6FE93D
    1 Fault Found:
    01304 - Radio
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 3
    Reset counter: 152
  3. @udi A3
    1,803
    192
    Simple solution to my own question thanks to rosstechs reply and a little more googling.
    problem now solved :D
