trouble with a3
Jay-a3 Mar 9, 2010
  1. Jay-a3
    Jay-a3 Member
    135
    hi peeps, i recently changed my maf sensor, its not a genuine bosh one and ever since ive been getting a 17705 code. would this be because of the maf sensor or something else?the engine management light was on before i changed the sensor an it went of as soon as i changed it and hasnt come back on.
    anybody have any ideas??
    thanks alot
  2. Jay-a3
    Jay-a3 Member
    135
    its a 1.8t by the way lol
  3. finesse
    finesse Active Member
    2,805
    Not the maf sensor; probably a split hose somewhere
    17705/P1297/004759 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
    Possible Symptoms
    * Power Loss
    Possible Causes
    * Leaking hoses and/or pipes between components
    * Check Boost Pressure Control Valve (N249)
    Possible Solutions
    * Check hoses and/or pipes between components
    * Check / Replace Boost Pressure Control Valve (N249)
    * Check / clean Throttle Valve, do Throttle Body Alignment
    Special Notes
    * Did anyone fitted an extra (wrong) dump valve?
  4. finesse
    2,805
    Someone more knowledgeable can answer this
  5. Jay-a3
    Jay-a3 Member
    135
    i have had an extra dv fitted but it seems to be working fine and there is no signs of split pipes. sometimes when starting in the morning it struggles to run so last time it did this i umplugged the maf and the car idles fine then?is that just a coinsidense. the codes intermitent by the way
  6. ALPINE
    3,093
    jamie , dont suppose you have your old knackerd maf do you?
    My moneys on a vac leak somewhere.
  7. DJ_Troopa
    DJ_Troopa K1 Driver
    1,743
    14
    I thought the non genuine Bosch MAF's were **** as a few people have had bad experiences with these. My friend had one on his A4 and it cocked up within 2 days!
  8. finesse
    2,805
  9. Jay-a3
    Jay-a3 Member
    135
    yes alpine i have my old one mate.
    so you recon it could be it trooper?is there any way a garage could test the maf?
  10. ALPINE
    3,093
    Jamie, if you have no use for it im after a MAF housing (with out the sensor) i de-meshed mine (as most do) but my car dont like it... want to sell me your busted Maf dude?
  11. Jay-a3
    Jay-a3 Member
    135
    i cleaned the old one last weekend and when i went out for a spin the car felt like it was missing when driving.didnt let it dry for an hour tho more like 15mins
  12. Jay-a3
    Jay-a3 Member
    135
    sorry alpine i only replaced the sensor dude so i still use the old housing. what does de messing it do?
  13. ALPINE
    3,093
    ahhh no problem! some say its restrictive, i day its needed, as mine has flat spots now where it didnt before. my sensors fine and i cant just buy a housing! gotta love audis!
  14. Jay-a3
    Jay-a3 Member
    135
    you tried ebay? so you think it may be a vac leak then?would that cause the dodgy running.stalls sumtimes
  15. ALPINE
    3,093
    yep and yep! :) if the revs are going up n down all the time it could well be a dirty Throttle body.
  16. Jay-a3
    Jay-a3 Member
    135
    ok thanks matey ill let ya know what it is
