Trouble changing from 1st to 2nd & 3rd to 2nd
clem2192 Dec 3, 2009
  1. clem2192
    clem2192 Member
    174
    Guys/Gals,
    This is my first post after recently joining up.....
    I have recently changed from a MK4 Golf 1.8T to an A3 3.2 Quattro (will put pics up at some point)
    The trouble I am having is when changing up from 1st to 2nd or changing down from 3rd to 2nd I get a horrible jerk!!
    I am not sure if this is a common problem or whether I just need to learn to drive again :racer:. I have never experienced this problem with any other car I have owned.
    Nice One!
    Ryan
  2. stealth64
    stealth64 Member
    201
    Not an expert at all on this, but had a problem with my previous car with just one of my gears, it turned out needed a new gear syncro fitting (or however you spell it!), not a massive job and even better if you have some warranty on the car!
  3. edition
    edition Active Member
    1,426
    They are very difficult to drive smoothly. I think that this is a mix of there being quite alot of torque, being low geared and a small car.
    Hard to tell if yours is normal or somthings up without driving one back to back! Engine mounts could be shot...
  4. Khufu
    Khufu Well-Known Member
    5,704
    31
    isn't most of the VAG range a bit funny between 1s and 2nd?
  5. smbAudi
    smbAudi Member
    93
    not knowing that much about the 3.2 models generally a crunch between gears is either clutch or gearbox related. When changing into 2nd make sure the clutch is fully depressed...if this is the case and the crunch is still there then it sounds like the previous owner has done a lot of quick starts and possibly damaged the Synchro on 2nd gear which mean a rebuild of the gearbox and replacement part.
    Depending on how complex it is to get the gearbox out then the cost can be anywhere up to £500 on non specialist cars...food for thought!
  6. stealth64
    stealth64 Member
    201
    Nah that can be right. I had at least 2 syncros replaced on my Civic Type R and never needed the gearbox rebuilt and car was fine afterwards!
  7. clem2192
    clem2192 Member
    174
    This sounds like the problem more than a gear syncro problem as there is no clunking etc.....
    Maybe I just need to learn how to drive it smoothly :think:
  8. mac1403
    mac1403 Member
    972
    Have found the same thing with mine. 1st to 2nd is near impossible to be smooth in. Although I have noticed that instead of using first gear just to get moving try waiting to about 4k rpm before changing, this seems to make things a little smoother.
  9. clem2192
    clem2192 Member
    174
    Thanks will give that a go.....guess its just a case of suck and see!
  10. GConn
    GConn Member
    236
    I find it difficult to get into 2nd in the morning before it gets into working temp, but I get no noise. I think it's the gear box oil and I'll be changing it soon to see what effect that will have. HTH
