Trolley Jack and Axle Stand points on B7 A4
Ryan_Hol Mar 20, 2011
  1. Ryan_Hol
    Ryan_Hol Member
    121
    anyone got an under-body picture of where these are as i don't want to damage the sills, thanks
  2. rowdyboy
    rowdyboy Member
    804
    19
    There's a little arrow underneath each corner for the jack points.
  3. gphilla
    gphilla Member
    177
    I have a question regarding this - if you use your jack to jack up the car using the marked jacking point then were do u put the axle stand as the jacks in the way ???
  4. Sam W
    Sam W Member
    175
    On the lower arm mounting points would be a suggestion! Also always a good place to jack a car up if you don't know the jacking points or you suspect them to be corroded.
  5. dubdemand
    dubdemand VAG Addict
    405
    /\ what he said... I was unsure where to lift the car from with my trolley jack when I swapped my rims over so went for the suspension arm mounting points too.
    In the past I have made up wooden plates to sit between the cup of the trolley jack and the sill jacking points to help protect them - deffo worth doing if you need to jack it up to get an axle stand under there!
  6. todgerino
    todgerino New Member
    23
    I did this at the weekend for the first time for an oil change - was unsure what my options were, so I put the trolley jack right next to the axle stand - worked ok but a bit of a pain in the ar5e.
    I'll use the suspension mounts for the stands next time, but was unsure how/where to do it..just learning.
  7. Sam W
    Sam W Member
    175
    Anywhere thats bolted to the chassis is normally a good bet, as those points are often reinforced to take the weight of the car, they are after all what you car uses to support its own weight when the wheels are on the deck :yes:
