TRIP, DIS, On board computer.
Gambba Feb 21, 2003
  1. Gambba
    Gambba Active Member
    1,361
    Anyone know if this is as simple as just taking a cluster out of a scrap A3 and fitting it?
    I have climate control so don't think I'd need some of the sensors, for outside temp etc. Is the wiring already there for it? the ECU's don't change, which I guess is where the display gets it's info from.
    Any ideas, just a general question.....I'm a freak for gadgets!
    any comments wellcome...i.e. it's a waist of time, save your money you dumbass fool etc. etc.
  2. mramage
    mramage Member
    516
    I looked into this in my A4. Apparently it requires a new ECU as well, so I just dropped it.
    Like you, I hoped it was just the cluster and control. /ubbthreads/images/graemlins/cry.gif
  3. Khufu
    Khufu Well-Known Member
    5,704
    31
    A man after my own heart. I don't have Climate/aircon so it would be a bit harder for me probably. I can't see any extra wires mentioned for the loom in the ETKA parts CD but one of two conectors has two different codes allbeit the last letter of the code. No 93 & 94
  4. Gambba
    1,361
    [ QUOTE ]
    [/ QUOTE ]
    Looking at ETKA, the only difference on ECU's is the engine type, serial number and whether or not it has cruise control or not. The only reason I can think that cruise control matters is so the ECU is a straight fitment without the dealer having to enter the code through VAG-COM, so I can't see why the ECU would need changing.
    The ECU is already monitoring most of the items that the computer shows, that's how VAG-COM can give you a read out on a lot of things.........I maybe wrong however.
    On the climate control you can already get coolant temperature, speed in MPH/KPH, engine RPM and various external and internal temperature values, so would think the ECU is also aware of some of these temperature values.
  5. mramage
    mramage Member
    516
    Everything should be there, but getting it to the DIS is a different matter. I called a local VAG specialist and apparently they looked at it before, but it's extra wiring and (they could be wrong) a different ECU (don't know why though!). May be different in the A3, but IIRC the connector is different in DIS/non DIS dashes, not just a matter of an "additional" connector. Could maybe faff something though /ubbthreads/images/graemlins/grin.gif
    This is just what I was told...
    khufu, were you not down before as being in the Scotland area, fancy coming to the meet 1st March? /ubbthreads/images/graemlins/groovy.gif
  6. Khufu
    5,704
    31
    Shame we dont know someone who works in a Audi/VW dismantler to check the difference for us /ubbthreads/images/graemlins/cool.gif Sat 1st, 9.15am, Travel Lodge, Kingsway West, Dundee? I will see what I can do. I normally work weekends at the moment but I may be able to get the Sat off and start late on Sunday. Will get back to you...
  7. Khufu
    5,704
    31
    checked the Edwin electrical manual, there are two displays - midline and with DIS, highline. There are 2 32 pin (blue + green) normal connectors at the back and a 3rd 20 pin (red) if there is a DIS connected. Model changes 1997,1998-2000,2001 on so if you did get one it would need to be same year. It also mentions a removable plate for retro fitting exterior temp sensor but doesn't go into specifics. I will look into that option as that was what I really wanted (wanted full dis but thought too much to do)
  8. Khufu
    5,704
    31
    err, oops, they all do in Scotland don't yours? /ubbthreads/images/graemlins/blush.gif
  9. worfke
    worfke Member
    55
    Nonono, you're not getting away with it so easily, send me a bottle of Edradour single malt and we won't talk about it any more /ubbthreads/images/graemlins/grin.gif
  10. zooplankton
    zooplankton New Member
    the funny thing is, if i remember correctly, on the user manual it says the outside temp is displayed default for non-DIS cars... or maybe i was reading it wrong /ubbthreads/images/graemlins/smile.gif
    ...my car (2002 A3 1.8) doesn't display the outside temp at all.
    i've got climate control too, but climate control monitors cabin temperature and not outside temp so i wouldn't think the thermometer is already installed?
    would be nice if i could get at least the outside temp displayed.
  11. Gambba
    1,361
    Zoop,
    First things first, Welcome to the boards /ubbthreads/images/graemlins/beerchug.gif
    A3's without DIS have no way of normally showing the ambient air temperature, however cars with climate control do the have the capability to display external tempretures when accessed.
    By this I mean that by enetering a code of a particular value you can see what the CC is seeing in terms of intake temps, exhaust temps, coolant temperature along a whole range of other figures. Rather than saying anymore check out this link to Audi-world, where someone has produced a nice table and accessing details to do with the 'secrets' of the CC.............so go play!! /ubbthreads/images/graemlins/grin.gif
    http://www.audiworld.com/tech/int5.shtml
    Gambba. /ubbthreads/images/graemlins/beerchug.gif
  12. zooplankton
    thanks.
    will certainly try that out when i get back to my car in three months (am working overseas).
    i miss my car. boohoohoo /ubbthreads/images/graemlins/cry.gif
