Trimming the climate control
khalil Dec 7, 2009
  1. khalil
    khalil Member
    774
    finally did the double din conversion,
    took like 2 hrs and lots of cuts later finally got it done.
    i need to trim the climate control now, any tips , guides, how much to trim etc..
    or has someone got measurements of the top of the climate and the bottom,
    any help would be very grateful
    cheers all
  2. -Ju-
    -Ju- Well-Known Member VCDS Map User Team Panther Audi S3
    2,398
    509
    When I did my old A3, I just trimmed a piece of card from a cereal packet till it fitted neat and then took the measurements off that.
  3. khalil
    khalil Member
    774
    what you use to cut it, a gigsaw?how about if you use a sharp stanly knife and keep scoring it until it cuts trough, will that work?
  4. -Ju-
    2,398
    509
    Don't use a jigsaw, you'll make a right mess of it lol!. Use a hacksaw and then sand the edge with sandpaper and a block of wood.
    There's not much to come of if I remember right, it's just the bottom half that angles in about 10mm on both sides.
  5. Khufu
    Khufu Well-Known Member
    5,704
    31
    I did the same as 3.2 Ju, few mins to cut and hours of slow sanding, I was paranoid of taking too much off so took longer than it should have LOL
  6. khalil
    khalil Member
    774
    when you cut the sides off, does it still fit in the groves of the double din cage, meaning is it secure?
  7. -Ju-
    2,398
    509
    Yep it does. Don't panic mate, it's not hard just a bit scary!
  8. khalil
    khalil Member
    774
    lol i know what you mean, it is sort of scary cause if you make a mess of it than its going to cost ££££££££££££ lol
  9. Khufu
    5,704
    31
  10. khalil
    khalil Member
    774
    oh thats ok, out comes the hacksaw lol and maybe a machete lol
  11. V6Pete
    V6Pete Now running on Bentley's y'all
    1,491
  12. Khufu
    5,704
    31
    The sides look closer to the dials & they guy is also selling the stereo which is a double din.
    Theres another one with switches for heated seats but its £225 LOL
  13. V6Pete
    1,491
    That doesn't surprise me, I was fed up seeing these selling for too much cash, so let HazzyDayz chop mine down - they did a good job, but have done quite a few before. I'm pretty sure if I did it myself I'd have made a complete mess of it!!
  14. NHN
    29,561
    1,778
    Dremel is the best with a disc, tape up the sides with masking tape, then when cut of, the edges usually are left with small bits you can break of with ur fingers, mostly clean cuts, can be very litely sanded, fairly easy to do tbh, just get measurements as best as poss, has the slighted rounded edge so bare this in mind when doing.
  15. khalil
    khalil Member
    774
    rounded edge?
  16. NHN
    29,561
    1,778
    Ok you got me, slightly curved, lol
