Treated my injectors.
Gunner3011 Feb 16, 2014
  1. Gunner3011
    Gunner3011 Member
    41
    After recently buying my S3 I am now started to sort things out with regards getting a good basis to improve the power to Stage 2.
    Started things off today by giving the injectors a once over so here is the process :
    Initial ultra sonic cleaning to remove all the "gunk"
    Into the next ultra sonic cleaner after all the initial dirt has been removed
    All hooked up to the tester to visually observe the spray pattern which was pretty good
    Next was a leak test which I forgot to photograph but no leaks were found up to 7bar.
    The injectors were then fired for 15 seconds to observe if they all emitted an equal and correct amount of fuel
    For some reason the next few photos failed to capture properly but the results showed that 2 injectors were down and 2 were good. this process was repeated a further 2 times to ensure it was correct. Again the same 2 were confirmed down. Filter baskets were then removed and placed into a Third ultrasonic cleaner and electrical connectors which cycled the injectors to ensure all fluid was passed through the injector body and nozzle. This process was repeated several times with the injectors being retested until an acceptable result was achieved with all injectors producing the same volume of fuel.
    The new filter baskets and seals were then installed
    Finally, all done and ready to be re installed
    Now I know the injectors will not be causing any problems soon :)
    Nilz likes this.
  2. vrbob
    vrbob Thats no Moon, Thats a space station!
    2,375
    171
    Is this something you do for a living? if not who did you use and how much was the service if you don't mind me asking as looks like a great idea :)
  3. vivalacoulter
    vivalacoulter Active Member VCDS Map User Audi S5
    409
    61
    Very good! :)
  4. Gunner3011
    Gunner3011 Member
    41
    I'm a mechanic by trade in a small garage and a colleague of mine does this as a home business! He's still in the stage of building up stock to sell aswell as refurbing them but I've sent some mates his way already for it. Just finished helping a mate with an Ibiza cupra R doing a K04 conversion and he had 2 poor injectors which would have affected him greatly.
    The treatment mine had today I believe is £40 plus £6.95 for postage if that's how you choose to do it if you're not local
  5. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    mrinjectoruk did mine. Same service. Very good price
  6. vrbob
    2,375
    171
    Thanks for the info,
    Just need a couple of days when not using the car then so I can send them away to be serviced.
  7. Gunner3011
    Gunner3011 Member
    41
    What did they charge out of interest?
  8. Gunner3011
    Gunner3011 Member
    41
    No problem, as far as I know the day he receives them he Does all the work so at his end the turn around is nearly immediate!
  9. david7m
    david7m Active Member
    551
    44
    Looks good!
    How does the £40 compare against buying new ones ?
    Dave
  10. Gunner3011
    Gunner3011 Member
    41
    2 second search on ebay was £50 new buy it now on one unit, so very good in comparison
  11. superkarl
    9,623
    2,488
    I can't remember exactly, but in the same sort of region your mate charges. 40odd plus postage which is special delivery.
  12. daz-20vt
    daz-20vt Well-Known Member
    2,836
    584
    You guys notice any improvements in doing this? I thought it would cost a small fortune!
  13. superkarl
    9,623
    2,488
    I dunno I did it to sell my stock injectors as mint.
    people have been diy cleaning them for a while and report good things in smoothness and mpg. Several members have bought ultrasonic cleaners to do there's, they aren't expensive
  14. daz-20vt
    2,836
    584
    Yeh just seen they start at 20 quid lol. Can that really do the same job? Gotta be worth buying even for a one off
  15. Gunner3011
    Gunner3011 Member
    41
    A good ultrasonics cleaner dependant upon needs is £350 but the real kit is the tester to measure spray pattern and flow under different pressures etc. each injector will have a rated flow and it's all calculated properly until it reaches it's desired flow rate.
    Mine felt very smooth afterwards to drive, but I'm the case of my mate who had 2 injectors rated at "poor" he would have certainly noticed a huge difference.
  16. dentsy
    dentsy Loving my new to me allroad
    770
    53
    Wow what a fab idea ! Is the price the same for 2.0 tdi 140 injectors ?
    How close are you to South Wales ?
    Si
  17. Gunner3011
    Gunner3011 Member
    41
    Petrol injectors only I'm afraid mate!
  18. dentsy
    770
    53
    Dogs gonads 😒😒 can diesels be done ?
  19. Gunner3011
    Gunner3011 Member
    41
    Diesel injectors are much more complicated mate and I would imagine the process to be much more complicated if it is possible atall
  20. vrbob
    2,375
    171
    Perhaps point your mate in the direction of this thread as it may generate him some business.
  21. Gunner3011
    Gunner3011 Member
    41
    Ill let him know, would you think this service would be popular amongst the forum?
  22. superkarl
    9,623
    2,488
    He would need to apply to be a forum trader, otherwise it would soon get closed down.
  23. Gunner3011
    Gunner3011 Member
    41
    How would that work then does he email admin or something? Also what's the score with stuff like that as in if I want to a garage and they gave me a good service and I recommended them would the thread be deleted as they don't trade for the forum?
  24. superkarl
    9,623
    2,488
    Recommendations are fine, forum trading isnt.
    You need permission from admin yes.
  25. vrbob
    2,375
    171
    Best bet would be to contact the admin team to confirm but people often recommend business and services on here. eg like Superkarl did with MrinjectorUK above
    So if he has a website you could link to it as that makes no odds at all as far as I am aware (obviously with a forum discount lol)
  26. Gunner3011
    Gunner3011 Member
    41
    Gotcha, I've passed it onto him and he's going to look into it after work tonight with the Admin side of it etc!
    I recommend him as a great service though with fantastic value and impressive results ;)
  27. vrbob
    2,375
    171
    Nice always good to have good people with actual real world reccomendations
    I have found the service mrinjectoruk offer on ebay and looks like it works out at £45 for 4 injectors including postage
    Fuel Injector Ultrasonic cleaning Testing | eBay
    So if your mate can offer the same if not better service for the same or less he should do well
  28. daz-20vt
    2,836
    584
    How hard or easy is it to remove and reinstall the injectors? And do you need new seals after? If so where might i find them? Thanks !! Daz
  29. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    538
  30. Gunner3011
    Gunner3011 Member
    41
    The full price works out at £46.60 from mr injector as the postage listed is for one item but he applies discount for multiple items so he does however work out 35p cheaper.
  31. Gunner3011
    Gunner3011 Member
    41
    Very easy mate, undo 2 5mm Allen key bolts and remove each injector by pulling out the retaining clip and job done
  32. Wallm0nkey
    Wallm0nkey Member
    225
    I'd be interested in getting mine done just need to sort out when we can be minus the car.
  33. Gunner3011
    Gunner3011 Member
    41
    Turn around is very quick so there wouldn't be a weeks wait or that. The day they are received they are serviced and reassembled and dispatched the following morning via Royal Mail special delivery
    JD09 likes this.
  34. JD09
    JD09 I'm not modding, I'm improving VCDS Map User
    3,096
    46
    So if I've got this right, £45 ish for all four injectors cleaned and checked (no car issues, so presume mine are OK) by a pro, or £45 on a DIY kit (granted this could be used on friends and future cars)?
    Sweet, thanks Karl et al.
  35. Gunner3011
    Gunner3011 Member
    41
    £45 on a DIY kit? Lol there's a reason a proper set up costs thousands. The link posted above showing the DIY thing at home only cleans the outside of the injector?
    The injector wasn't pulsed to clean the internals, seats and Pintle but merely cleaned the outer body. The spray pattern wasn't observed nor was the flow rate so it is impossible to confirm if the injector is flowing correctly and producing the same as the other injectors and has no idea if the spray pattern is correct.
    Buying an ultrasonic bath will make your outer body clean and that's about it I'm afraid.
  36. kwistof
    2,434
    538
    I only put that link up there because Daz required a fitting/installation guide and that's pretty helpful (if pics are displayed).
  37. JD09
    3,096
    46
    You clearly know a lot about this subject, so not to doubt you, but surely if petrol can get in the top and out the bottom, cleaning fluid and water can also get in. And therefore, when in an ultrasonic bath, clean the insides as well? I appreciate it will not check the flow patterns. I am purely going off the thread linked in the stickies/above!
  38. superkarl
    9,623
    2,488
    JD, lots of members have bought US cleaners for their injectors, hell I did it about 3 years ago. Everyone inc myself reported smoother idle, running and mpg.
    However
    As gunner says, its nothing on the service his mate and mrinjector UK offers. For £45 use a pro service.
    for an old car with old injectors I think its worthwhile doing it once.
    Thanks to gunner for providing people with an In depth review
  39. Gunner3011
    Gunner3011 Member
    41
    Petrol is forced through the injector though and not simply left to find its own way through. also if your injector was blocked it would require pressure from the electronic pulsing to clear it or even back washing to remove it. The cleaning is only a minor portion of the objective too, testing the injectors for leaks, spray pattern and equal/sufficient flow is arguably the most important stage. After all, what use is a clean injector that starts leaking under 3 bar of pressure?
    In reference to petrol can get in and out of the injector, true! ... But only if electronically controlled. Hence the electronic pulsing off injectors whilst in the ultra sonic tank. Without the electronic signal to operate the solenoid inside the injector, the pintle will remain closed therefore allowing no fluid to pass. If fluid is passing then your injector is leaking but you may not be able to tell this as the injector would be submerged which is where all the testing equipment comes in highlighting such a problem.
    Hope this clears up any queries on this subject :)
  40. Gunner3011
    Gunner3011 Member
    41
    Here's a picture that failed to upload yesterday showing the injectors being pulsed in the solution to fully clean the internals.
