  1. drew collins
    drew collins New Member
    :redrs4:does anyone know if i can transplant my audi 1998 a4 2.5 tdi 2wd auto triptronic into my new 2003 audi a4 1.9 tdi auto triptronic as the clutch has gone on the 2003 car i have been told it will be approx £700 to repair
    :blackrs4:
  2. Broken Byzan
    13,237
    465
    I hate to tell you this, but you do not have a clutch fitted to either car. Was that what you were told by a garage?
  3. aragorn
    18,544
    865
    perhaps the torque converter has gone? as thats what acts as a clutch in an auto...
    As to transplanting the entire engine, yes its possible, but it certainly wont be plug and play. If your lucky you might be able to utilise the torque converter from the older car with the newer gearbox, and then break the older car for parts...
  4. Siena
    Siena Active Member
    2,626
    Torque converter is not compatible between the 4 and 6 cylinder car.
    Transmission aren't either. Even the auto tranny of a '98 2,5 TDI is not compatible with a '00 2,5 TDI, as the ECU's that control them are completely different.
    The connectors that go onto the transmission are different too.
