Transmission oil change interval..
demus Oct 10, 2013
  1. demus
    demus Fire in the hole..
    355
    19
    Does anyone happen to know the interval for changing the transmission oil on an AWX 5 speed.
    Can't say I've noticed it in the service schedule anywhere..
  2. white.akita
    white.akita Active Member
    322
    30
    Sealed for life according to audi.
    Imo manual gearbox oil in audis doesnt need to be changed even when it gets dirty my audis have changed gear perfect.
    if you want to change it use genuine audi oil only.
  3. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    no oil lasts forever ... change the oil when you can , same for diffs also
  4. scott b
    scott b Active Member VCDS Map User
    1,254
    and to make it easier to change use a fluid transfer pump, trying to get oil back into the gear box using the standard bottles is a right twat
  5. white.akita
    322
    30
    The manual gearbox oil in all the skoda taxis round my way never gets changed in 300,000 miles without any problems.
  6. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group s tronic
    3,939
    735
    I changed the oil on my box after 270K, first a second gears where a little notchy after the oil change it was back to normal. The oil in the box was not in the best of condition compared to the new oil. However I don't think Audi "sealed for life" = 270K & 13 years.
    It's such an easy job & cheap job to do, as for filling the box I used a length of clear hose and ran the fluid through that.
  7. dualmono21
    1,138
    cheap easy job to do ... or risk a gearbox failure
    your choice
    see what audi say when the gearbox fails ... see if they will replace it f.o.c
