Tranny Trouble ?
Discussion in 'A4/S4 forum(B5 Chassis)' started by DavidT, Jan 2, 2003.
  1. DavidT
    DavidT Member
    Jan 2, 2003
    72
    Hi all,
    I can see there is a lot of info on the forum for the 2.0T engine and that Audi basically seem to have admitted there is a problem with that engine but what about the 1.8?
    I recently bought an A3 1.8T Quattro (9th October). The oil was changed by the dealer (non-Audi) before I bought it. 2 weeks ago the oil light came on, I assumed that they may have just only filled the oil to just above the min so put another half litre in. Yesterday (after less than 200 miles) the oil light is back on. The car has 110K miles on the clock.
    To make matters complicated, I live in Switzerland and I bought the car here but form a dealer a 4 hour drive away. Any idea about where I should start?
    Thanks guys
    C
  2. Advert Guest Advertisement
  3. toasty
    toasty Member
    Jan 2, 2003
    52
    Wow 5000rpm then dump the clutch!!
    You must be brave.... or silly /ubbthreads/images/graemlins/smile.gif
    Does the car still work ok?
    I thought the centre diff was just a fluid coupling (like a torque converter on an auto) so I can't imagine there would be much in it to make a banging noise.
    Have you tried running VAG COM to see if any DTCs were recorded? (my guess is that it was the engine or exhaust)
    -Dan
  4. Joshie
    Joshie Member
    Jan 5, 2003
    71
    I know where you're coming from Dave. I did the same thing repeatedly at Elvington and then the following week at Santa Pod. Damaged the input shaft and synchro rings as well as one or two other bits and pieces.
    The car has been at the gearbox rebuilders over Chritsmas. Hopefully I'll get it back this week sometime.
    If you do need to have damage repaired then I would recommend that you have a local gearbox specialist break down the box and then you source the spares through VAG Parts. Martyn literally saved me a fortune over the listed pricing.
    Fingers crossed it's nothing serious.
  5. Joshie
    Joshie Member
    Jan 5, 2003
    71
    Bit off topic I know but I got the same lead from Sk (OBDII) and I use the shareware programme from Ross Tech (tight git I am). Anyhow it works great although it hangs when I try data logging. Are you using the registered software or the freebie one from Ross Tech?
    Also I run Win 2000 on my laptop - what do you run Dan?
  6. toasty
    toasty Member
    Jan 2, 2003
    52
    No I'm using the freeby too, but I'm not stingy, just broke!!
    The logging works fine for me, but I suspect my laptop is of a slightly lower spec than yours!! (486 DX33 20Meg ram running win 95)
    Get one off e-bay, they go for about £50 or less.
  7. Joshie
    Joshie Member
    Jan 5, 2003
    71
    £50 - is that all - well worth it. And the PC is company property - don't fancy breaking the screen on the road test!
  8. Mutley
    Mutley Member
    Jan 3, 2003
    67
    Hey shame on you Dan!! If this is an S4 we are talking about then it has a superb piece of engineering known as a Torsen Diff in the centre. Only the A3Q / S3 / TT use a viscous coupling (Haldex) which is a reactive rather than proactive system (makes all the difference).
    Yep - ok, I swallowed an automotive engineering dictionary over several years but check out this http://www.audi-sport.net/ubbthreads/showflat.php?Cat=&Board=generalchat&Number=1303&page=0&view=collapsed&sb=5&o=&fpart=1 - it explains things like Torsen Diffs and Haldex Couplings really well.
    Jon
  9. quattropaul
    quattropaul New Member
    Jan 2, 2003
    9
    [ QUOTE ]
    [/ QUOTE ]
    Ian
    How's the car coming on ? /ubbthreads/images/graemlins/smirk.gif
  10. Joshie
    Joshie Member
    Jan 5, 2003
    71
    Got to give them a call today to see when they expect it to be comleted.
    As you know they were closed right over Christmas, only returning yesterday.
    So hopefully by the end of the week /ubbthreads/images/graemlins/cool.gif
    PS - Didn't realise your true profession /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif /ubbthreads/images/graemlins/grin.gif
  11. toasty
    toasty Member
    Jan 2, 2003
    52
    Did I say viscous coupling? .... I meant torsen diff (honest!!)
    Well you learn something everyday. /ubbthreads/images/graemlins/grin.gif Thanks Mutley.
    It's (the torsen diff) certainly quite mechanical inside, so I guess it could have made the banging noise originally described
  12. Joshie
    Joshie Member
    Jan 5, 2003
    71
    [/ QUOTE ]
    Ian
    [/ QUOTE ]
    Well the latest is that the Box has been rebuilt and is back in the car. When I phoned the car was on road test. Don't muck around these boys (they just take long holidays!).
    So hopefully tomorrow or latest Thursday. And the damage?, I asked, we'll let you know, he said /ubbthreads/images/graemlins/frown.gif
  13. Mutley
    Mutley Member
    Jan 3, 2003
    67
    No worries Dan. I would have thought that any bangs from the Torsen diff though would be horribly terminal... /ubbthreads/images/graemlins/frown.gif My best theory would be that when torque was transferred to your rear wheels (by virtue of their extra grip from the weight transfer and the torsen action), that the subframe containing your rear diff moved on its flexible mountings and caused the bit where the propshaft enters to go 'nose up'. This will upset the geometry of the CV joint and it will cause the propshaft to make a loud bang every half turn . . . but non terminal once the excessive torque is removed. May be a good idea to make sure the rear propshaft CV joint boot is intact.
    I have seen this before on tuned cars with live axles - it is more pronounced because often the 'u' bolts holding the axle to the leaf springs are the only thing stopping the diff casing from going 'nose up' under acceleration. This is obviously much more crude than the subframe arrangement of the S4 but the forces are all acting in the same direction.
    Just my theory anyway
    Jon
  14. sfource
    sfource New Member
    Jan 7, 2003
    12
