Trailing arm bush replacement (s3)
s3dave Feb 18, 2012
  1. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    My car was getting very nervous on the road and started skipping over rough patches /grates ive had this on my old BMW so i knew what it was, the bloody trailing arm bushes....
    So i replaced mine today, not a job for the faint hearted as your stress levels go through the roof, especially when the last guy that 4 wheel aligned my car rounded one of the bolts, the hardest one to get to as well right up in the chassis...:no: i ended up chiselling it off
    20,000 swear words later i was left with this....
    To the untrained eye it does not look to bad....but i put a screwdriver in the middle and it could be turned at least 45 degrees and was as soft as jardos A3...:)
    So the drilling and cutting began, fairly easy to be honest and then it knocks out at the rear...
    Then the New bush is easily installed after been lubed up...
    Put back together very easy and the difference on the road is like night and day...much more planted
    if you are doing this pull the brake pipe from its holders around the petrol tank before you attempt to move the arm or you will snap the brake pipe, when it is loose there is plenty of play in the brake pipe when dropping the arm
    now got to pay another arm and a leg to get it 4WA again...ah well the joys of motoring eh....:icon_thumright:
    S3_OL likes this.
  2. Welly
    Welly VX220 SC Driver :)
    10,696
    130
    I really must do mine to be fair, mine is starting get a get nervous as time goes on. The winter not helping matters but I suspect that this will be the lead cause...
  3. superkarl
    superkarl MAN OF STEEL
    9,623
    2,488
    Nice one dave. I shouldve drilled mine but, mine looked totally fine.
    Doubt il get mine done before alignment on wednesday :(
    How long it take you?
  4. s3dave
    10,110
    736
    Well with seize/rounded bolt about 5 fkn hours... I would get yours done Karl, the rubber looked ok but had totally gone soft, not a nice job but the end results def outweigh....
  5. Broken Byzan
    13,244
    468
    Deffo worth doing then.
    I need to do mine to as it wanders around especially on motorway ruts etc.
    It's much easier to fit the powerflex over the OEM for sure
    "As soft as........... .." LMAO
  6. superkarl
    9,623
    2,488
    il pull my finger out then.....
  7. s3dave
    10,110
    736
    Welly yours is getting nervous because it never knows what turbo it's got in it.....lmfao..
  8. Westy
    Westy Well-Known Member
    17,443
    1,105
    Thanks Dave! Something else to do :(
  9. StaceyS3
    StaceyS3 Well-Known Member
    2,507
    506
    Can't say how much the rears helped directly on mine as done the whole car and arbs at the same time but it certinally tightened things up a lot :)
  10. doublem_1
    doublem_1 Member
    500
    Trying not to sound too daft but how can you tell if this needs replacing?
  11. sportstractor
    sportstractor Chugger
    2,709
    This:
  12. brasiliangringo
    brasiliangringo Member
    626
    10
    Do you think most +90k s3s would need this doing ?
    Also, are any of you able to comment on the control arm bushes - are these fairly hard wearing on an s3 or also likely to need doing at the same sort of time on a high mileage car? Suppose its a hard question as depends how its been driven..
  13. Westy
    17,443
    1,105
    I had a look at this bush when I was under my car tonight and it looks like a royal pita to get the bolt out! The bolts look super rusty and will probably round off. Deep joy!
  14. s3dave
    10,110
    736
    How does your car feel on the road? if it seems ok you should be ok but at 90+k they have had a good innings anyway, not the most pleasureable job, but once there done they should see the twilight years out nicely...
  15. brasiliangringo
    626
    10
    Thanks, i havent got one yet!! Just doing my homework.. Already lining myself up for a golden oldy..
  16. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Holy thread revival!
    s3dave - did you polybush this or go with an OE bush?
  17. s3dave
    10,110
    736
    Powerflex mate...
  18. [Dave B]
    [Dave B] Daddy
    2,027
    145
    All still well 12 months on?
  19. s3dave
    10,110
    736
    Yes mate, and its had stick, very worthwhile,....
  20. s3clarke
    s3clarke Money grabbing s3!
    677
    35
    this along with my top mounts and anti roll bar bushes is next on my list. all powerflex.
  21. cecilthesausage
    cecilthesausage ...It's Never Finished...
    933
    I've just polybushed mine before Xmas....
  22. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Thanks chaps :)
  23. sandwich1987
    sandwich1987 Member
    247
    14
    Just try'd to do mine there, when undoing the trailing arm bolt instead of the bolt coming out its just pulled the metal collar right through the Center of the old bush, think the bolt has corroded with the metal collar, any tips? Lol
  24. dre_S3
    dre_S3 Active Member
    756
    39
    Prob better of getting a new bolt mate for both sides, you got a TPS near you ?
  25. sandwich1987
    sandwich1987 Member
    247
    14
    I've got one near enough, but its getting the old one out....it's stuck solid to the metal insert inside the trailing arm bracket.
  26. sandwich1987
    sandwich1987 Member
    247
    14
    Any one got any ideas with this sleeve and bolt issue?
  27. @udi A3
    @udi A3 Site Sponsor Site Sponsor VCDS Map User
    1,819
    197
    Do you have a photo?
  28. sandwich1987
    sandwich1987 Member
    247
    14
    I don't mate ATM the picture s3dave has at the top of the page gives you an idea, it's the metal sleeve in the Center that's turning when you try to loosen the bolt that attaches it to the trailing arm bracket. I've try'd a punch from the nut side to try an push it through the sleeve but its not budging.
  29. sandwich1987
    sandwich1987 Member
    247
    14
    photo.jpg well finally managaed to get my drivers side bush done this is what was causing the issue, the bolt is completly solid inside the bush sleeve, had to drill and cut about 10mm of the bush and also cut the head off the bolt in order to get it free from the trailing arm bracket. for reference the bolt is an M12x1.5x80mm just going to order some instead of going through the dealer.
  30. hardhitter
    hardhitter Member
    138
    Screws like that are often pretty cheap from the dealer or tps (a pound or two) and the nuts are cheaper, probably cheaper than ordering from a engineers suppliers or hardware place as a lot don't carry that pitch in M12. You know you're getting the right grade and the plating is normally more durable too.
  31. Erf
    Erf Member
    243
  32. dre_S3
    756
    39
    Looks good to me, great mod to :)
  33. Erf
    Erf Member
    243
    Anyone know what the equivalent oem part number is by any chance?
  34. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Well what a fag of a job this is! I'm working through installing my new suspension bits and I'm having this exact problem, bush collar sized directly to the bolt.
    Sandwich - what did you cut it out with in the end?
  35. sandwich1987
    sandwich1987 Member
    247
    14
    In the picture the threads at the top were covered by the rest of the Bush, I just drilled about 6 holes all around the outside and chiseled off the rest. After cutting the head of the bolt off this gave me enough room to drop it out off the bracket, was a complete bar steward!!!
  36. [Dave B]
    [Dave B] Daddy
    2,027
    145
    AMEN to that! I managed to get the drivers side one out last night, I've yet to see if the passenger side one has seized as well. Had both sides of yours seized?
  37. s3clarke
    677
    35
    see im half heartedly deciding whether to attempt this tonight after ive done my coilovers :/ the job looks straight forward, but I guess its really not haha.
  38. [Dave B]
    [Dave B] Daddy
    2,027
    145
    It's straightforward IF the bush collar isn't seized to the bolt. If it is seized to the bolt then I'd advise taking it to a garage and paying someone else to get pissed off with it!
  39. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,305
    375
  40. superkarl
    9,623
    2,488
    Theyre both the right ones alex. God knows why the superpro are so expensive.
    I have the powerflex one myself
