tractor like sound on idle
deano1978 Feb 28, 2013
  1. deano1978
    deano1978 different gear
    713
    81
    Sounds like something rattling,loose like tractor sort of noise.
    It only happens on idle. When revved it goes away.
    Ive looked under the hood and the sound is coming from alternaor fan belt thingy.
    Whats on its way out??? Any ideas? alternator pulley was done 3 months ago
  2. abyrne153
    abyrne153 Member
    122
    Sounds like the clutch in the alternator pulley
  3. deano1978
    713
    81
    Thanks for reply.
    New to me.. Clutch pulley?
    Cld you tell me more?
    Big fix?
    Ok to drive?
    Please.
    Goint to take it garage tomoz.
  4. stu_m
    stu_m Well-Known Member VCDS Map User
    1,441
    the alternator has a clutch pulley to allow it to turn freely when starting to reduce the load once its running the pulley is engaged so the alternator spins up
    not sure how easy it is to change though
    It could also be the air con pulley rattling if the buffers in the pulley are worn to check that simply hit the econ button on the climate while you have the window wound down and it will get louder if it is that
  5. deano1978
    713
    81
    Cld it really be clutch pulley again.
    Iv just messed around with ac and econ. No different!.
    Garage it is.
    Mind you,if it is pulley,should be covered as its only just been done.
  6. abyrne153
    abyrne153 Member
    122
    the clutch pulley will cost something around £30. You need a special tool to remove the pulley. Check out youtube alternator clutch replacement for a demo on how to.
  7. pauldazzle
    pauldazzle Well-Known Member
    1,191
    95
    Switch the Econ button on & off with bonnet open. If it has an effect on the rattle the AC compressor pulley is goosed.
  8. deano1978
    713
    81
    Thanks but tried it last ngt with no difference.
    Off to garage now.....
  9. deano1978
    713
    81
    Just been my local garage and there baffeled?
    They come to the conclusion its the ac pump. Not a cheap fix.
    But i have a warrenty with motor thats soon to run out. Lets hope im covered.
    Part is £260 inc vat + labour
