Traction Control Wont Turn On When Driving?
VTI_EG_DAN Feb 14, 2009
  1. VTI_EG_DAN
    VTI_EG_DAN Member
    93
    Hey all,
    I went to view an s3 today, decided not to buy it in end as all seemed a bit dodgy!
    but the traction control wasnt working properly
    it would turn on when the ignition was on, and stay on when started the car, but as soon as u start driving, it would turn straight off, and then the button for it wouldnt do anything, and u couldnt turn it back on?
    is this a common fault? and is it easy fixed?
    just so i know when i go and look at other s3s!
    Cheers Dan
  2. S3 NIK
    S3 NIK Member
    190
    The esp light comes on with ignition then should go out as with the air bag light for example. The only time its lit is when you turn it off as a reminder its been manually turned off and when its actually working ie when you are losing traction, when this happens it flashes on and off quickly.
    Nik.
  3. VTI_EG_DAN
    VTI_EG_DAN Member
    93
    yeh this light was on the whole time when driving, and when car was started the button wouldnt do anything, and warning light would just stay on
  4. S3 NIK
    S3 NIK Member
    190
    In which case there's a fault somewhere and it would need a diagnostic check to pin point the fault.
    Nik.
  5. benr
    benr Member
    819
    Yep there will be a problem with it. as mentioned above It whould be off after you have started the car unless you turn it off by pressing the button.
    it could be a common problem as some of the sensors are known to fail, but needs a diagnostic scan to find which one. I wouldnt buy it until its sorted though
  6. Yaz
    Yaz Member
    225
    More than likely the longitude sensor or something like that has failed and needs replacing. This is a common problem with the TT also.
    When this happens, its ok to drive the car but just means the ESP wont work!
  7. mad max
    mad max sixth gear
    338
    has the battery been played with because there is an plug in on the back of it and if its not making a good connection would cause this type of fault.easy to check and could save you money if it is this
  8. <tuffty/>
    21,686
    4,116
    Mine used to come on due to the problem I had with my MAF. It did take a while but after a bit of spirited driving it would come on and sta on until I turned the ignition off.
    VAGCOM would help you... it may be a fault that a cheap fix or a way of getting a good price on an otherwise decent car.
    The seller must have known there was a prob (even if they don't know what it is)
    Good luck finding a car, its a buyers market and the right one will come along :)
  9. HTC
    HTC Active Member
    3,428
    9
    Can also come on with a bad ABS sensor.
  10. benr
    benr Member
    819
    Yep but the abs light would also be on.
