Traction Control Light Problem
adamf200 Nov 17, 2010
  1. adamf200
    adamf200 Member
    71
    Hi all,
    I have a 2000 A3 1.8 T-Sport Qauttro and since last week 2-3 minutes after start up the traction control light comess on and stays on.
    Any ideas?
  2. G60DAN
    G60DAN Member
    384
    Have you put it on VAG COM ?
  3. adamf200
    adamf200 Member
    71
    no, sorry to sound stupid but I have no idea what that is?
  4. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Suspension work done recently? or a bad pothole? it could be the geometry is slightly out....
  5. adamf200
    adamf200 Member
    71
    I normally drive the car with just me in it, but On Saturday on the way to the football there was 4 guys in the car! Thats when it first came on!
    Could that be anything to do with it?
  6. aragorn
    18,665
    880
    You need to scan the car with vagcom.
    This is a diagnostic utility, similar to what the dealers use, and it will query the cars electronics and find out why the light is on.
    If you post up your location, there may be someone on the forum who lives nearby who would be able to scan it for you.
  7. pj123
    pj123 Member
    307
    13
    If it is when you touch the brake pedal then it could be the brake light switch on the pedal. They are known for failing, easy diy fix and cost under £10. One possibility.
  8. leshkin
    leshkin Hold my beer... VCDS Map User Gold Supporter Team Sepang Audi S3
    2,719
    1,618
    +1 for brake light switch - if it disappears after the ignition is switched off then on, and comes on when the brake is applied - you will likely find that the brake lights are not working if switch is the problem.
    In reality there can be a number of reasons for the light, so search on the link in my signature for members with VCDS (new name for vag-com) near you, who will often do a scan for free or some beer ;) Alternatively, your local Audi dealer will scan your car for about 70 notes (if only I could earn 70 in 5 minutes.... :) ).
  9. Speedy Steve
    Speedy Steve Active Member
    1,258
    sounds to me like the lateral sensor for traction control but i would get it scanned first to be sure before going out and buying parts
  10. adamf200
    adamf200 Member
    71
    im planning on selling the car soon so I dont want to spend much on it!
    Is ther any way of getting the light to go out?
    Remove a fuse or something?
    Im in Lutterworth Leicestershire and work in Oadby Leicester if anyone near me has VCDS?
    Adam
  11. adamf200
    adamf200 Member
    71
    I have to say, Im 99% certain it came on this morning while i wasnt breaking but I will check on way home tonight and confirm 100% tomorrow, so I guess that rules out that problem?
  12. adamf200
    adamf200 Member
    71
    Ok think I have fixed it fingers crossed!
    It came on yesterday morning on the way to work, at sometraffic lights I turned engine off and straight back on, the light went out. I then pressed the ESP button to turn traction control on and off 4 times and it has come back on since! Done about 60 miles since and no warning lights at all!
  13. Speedy Steve
    1,258
    I used to live in lutterworth and now live over in oadby we could plug in my laptop and see whats wrong. youll find it will come back on soon its a faulty sensor!
