mike-turbo
- Joined
- Sep 6, 2009
- Messages
- 108
- Reaction score
- 5
- Points
- 18
hi ive got a golf plus 2011 i needed to change the steering rack after a small bump then i had the yellow steering light on and the traction control light on i took it to be tracked and now the yellow steering lights gone out ive just got the traction control light on ive tried the basic settting but no luck ive scanned it and this is what ive got.
Saturday,26,January,2013,11:23:24:27260
VCDS Version: Release 11.11.5
Data version: 20121222
Chassis Type: 7N0
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 61 62 72
VIN: WVWZZZ1KZCW501652
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: Cannot be reached 1100
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels: 03L-906-023-CAY.clb
Part No SW: 03L 906 023 MM HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 9050
Revision: --H43--- Serial number: 00000000000000
Coding: 08114034032501080000
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_ECM16TDI02103L906023MM 003006
ROD: EV_ECM16TDI02103L906023MM_VW36.rod
VCID: 7DFBFA77EC9B12F04AA
No fault code found.
Readiness: 1110 1000
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 263B400D092200FB641102E9901B0091310000
VCID: 7BFFF46FFA8F1CC074E
2 Faults Found:
00778 - Steering Angle Sensor (G85)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 6180 km
Time Indication: 0
Date: 2013.14.28
Time: 11:21:14
Freeze Frame:
Count: 3
Count: 2
Count: 29184
Count: 295
Count: 46336
Count: 0
Count: 1015
Count: 0
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 6180 km
Time Indication: 0
Date: 2013.14.28
Time: 11:21:14
Freeze Frame:
Count: 3
Count: 2
Count: 29184
Count: 166
Count: 46336
Count: 0
Count: 1015
Count: 0
Address 08: Auto HVAC (J301) Labels: 7N0-907-426.clb
Part No SW: 7N0 907 426 AM HW: 7N0 907 426 AM
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004003
ASAM Dataset: EV_ACManueBHBVW36X A01010
ROD: EV_ACManueBHBVW36X_VW36.rod
VCID: 7F07007FE69700E0586
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 1K0 937 084 F HW: 1K0 937 084 F
Component: BCM PQ35 B 110 0651
Revision: 00110 AC
Coding: 4C180A3A8825F1E0400800C0340000E44B510E88436D8960648087000041
VCID: 31631647684326909E2
Subsystem 1 - Part No: 5M0 955 119 D
Component: Wischer 24051 26 0513
Coding: 009795
Subsystem 2 - Part No: 1K0 955 559 AG Labels: 1K0-955-559-AG.CLB
Component: RLS 240511 05 55 0403
Coding: 4230BB
Subsystem 3 - Part No: 1K8 951 171
Component: DWA-Sensor 00 001 0104
Subsystem 4 - Part No: 1K8 951 605 B
Component: LIN BACKUP HO H11 9005
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 6180 km
Time Indication: 0
Date: 2013.14.28
Time: 11:21:42
Freeze Frame:
Term 15 On
Voltage: 12.90 V
ON
ON
Term 50 On
OFF
OFF
Address 10: Park/Steer Assist (J791) Labels: 1T0-919-475.clb
Part No SW: 1T0 919 475 P HW: 3T0 919 475 C
Component: PARKHILFE PLA H08 0116
Revision: -------- Serial number: 13991111968484
Coding: 10900B
VCID: 48955BA3FBD98758A9C
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6RA26SKW
Coding: 00003236
ASAM Dataset: EV_AirbaVW10SMEVW360 A01014
ROD: EV_AirbaVW10SMEVW360_VW36.rod
VCID: 3261194B65451D88E78
Crash sensor for side airbag; driver side:
Subsystem 1 - Part No SW: 5M0 955 557 HW: 5M0 955 557
Component: S.Sens.Fahr.V H01 ----
Serial number: 3572MSME1D58225EZZZ0
Crash sensor for side airbag; passenger side:
Subsystem 2 - Part No SW: 5M0 955 557 HW: 5M0 955 557
Component: S.Sens.Beif.V H01 ----
Serial number: 3582MSME5929235EZZZ0
Crash sensor for side airbag; rear driver side:
Component: S.Sens.Fahr.H --- ----
Serial number: 3511HSME73261D27ZZZM
Crash sensor for side airbag; rear passenger side:
Component: S.Sens.Beif.H --- ----
Serial number: 3521HSME752F1D27ZZZY
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 BA HW: 5K0 953 549 C
Component: Lenks.Modul 008 0080
Revision: -------- Serial number: 90422KEK0010F
Coding: 5080140000
ASAM Dataset: EV_SMLSNGKUDS A05001
ROD: EV_SMLSNGKUDS_VW36.rod
VCID: 70E5D343ABC96F98D1C
Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
Part No SW: 5M0 920 972 A HW: 5M0 920 972 A
Component: KOMBI H03 0607
Coding: 470B00
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
VCID: 306513436B492F9891C
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 J HW: 1K0 907 951
Component: J533 Gateway H43 1620
Revision: H43 Serial number: 270511F1000596
Coding: 359003
VCID: 3777285F8627F8A0D06
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 6180 km
Time Indication: 0
Date: 2013.14.28
Time: 11:22:40
Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
Part No SW: 5K0 953 234 HW: 5K0 953 234
Component: IMMO H03 0607
Coding: 000000
Shop #: WSC 00000 000 00000
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
VCID: EAD1412B0D1515481F8
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.lbl
Part No SW: 5K0 959 701 G HW: 5K0 959 701 G
Component: Tuer-SG 009 2122
Coding: 0131764
VCID: 3669255B412D01A8CB0
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 233 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 346D1F53575113B8F54
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.lbl
Part No SW: 5K0 959 702 G HW: 5K0 959 702 G
Coding: 0132020
VCID: 3777285F4627F8A0D06
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 5M0 035 186 J HW: 5M0 035 186 J
Component: Radio RCD310 031 0075
Revision: 01000001 Serial number: VWZ1Z2L3402368
Coding: 0500040004000A
VCID: 336F1C4F925F1480ECE
Address 61: Battery Regul. (J840) Labels: 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H43 1620
Coding: 030B185A
VCID: F1E3564728C3E6905E2
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 5K0 959 703 E HW: 5K0 959 703 E
Component: Tuer-SG 007 2101
Coding: 0131216
Shop #: WSC 01357 011 1012552
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 E HW: 5K0 959 704 E
Coding: 0131216
End ---------------------------------------------------------------------
Chassis Type: 7N0
Revision: 00H31001
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 6180 km
Time Indication: 0
Date: 2013.14.28
Time: 11:21:14
Freeze Frame:
Count: 3
Count: 2
Count: 29184
Count: 295
Count: 46336
Count: 0
Count: 1015
Count: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 6180 km
Time Indication: 0
Date: 2013.14.28
Time: 11:21:14
Freeze Frame:
Count: 3
Count: 2
Count: 29184
Count: 166
Count: 46336
Count: 0
Count: 1015
Count: 0
Revision: 00001015
Coding: 0000004003
Revision: 00110 AC
Coding: 009795
Coding: 4230BB
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 131
Mileage: 6180 km
Time Indication: 0
Date: 2013.14.28
Time: 11:21:42
Freeze Frame:
Term 15 On
Voltage: 12.90 V
ON
ON
Term 50 On
OFF
OFF
Coding: 10900B
Coding: 00003236
Coding: 5080140000
Coding: 470B00
Coding: 359003
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 131
Mileage: 6180 km
Time Indication: 0
Date: 2013.14.28
Time: 11:22:40
Coding: 000000
Coding: 0131764
Revision: 00H20000
Coding: 0132020
Coding: 030B185A
Coding: 0131216
Coding: 0131216
