Traction and abs light come on after checking fuses
johal87 Nov 14, 2009
  1. johal87
    johal87 Member
    331
    Preety much as title says
    I removed and checked everyfuse under the bonnet in the fusebox to see if any had blow, now the traction and abs lights have come on?
    Any ideas fellas?
  2. Khufu
    Khufu Well-Known Member
    5,704
    31
    Why were you checking the fuses in the first place? Have you driven the car to see if they go out if you drive over 15 mph?
  3. johal87
    johal87 Member
    331
    check if one of the fuses had blown causing the econ light to stay on
    yes I've drove it and they stay, if I turn the car off the traction light will go off and then come back on aftermovement
  4. paddy
    paddy Audi=No fault code, no idea
    5,152
    133
    Have you checked the fuses for ABS and TC again to make sure you have the right ones and that they are making good contact. Looks like the symptom you would get if the fuse had blown. try cleaning the contacts.
  5. johal87
    johal87 Member
    331
    I was thinking that dude, I've checked the fuses again but none are fused
    also I've checked the one inside and that's fine too
    has anyone got a diagram for the engine fusebox as I think that's were the problem Lies as that's all I have messed with and some of the fuse tips had White powder on??
  6. paddy
    5,152
    133
    What do you want ? a fuse position layout ??
  7. johal87
    johal87 Member
    331
    Yes if possible
    there's loads of codes next to them f1 etc but no meanings like the inside one as a layout and a meaning, I need to try and locate the ones with a meaning or cause to abs and traction
  8. paddy
    5,152
    133
    Give me a minute....
  9. paddy
    5,152
    133
    Is this the layout you have ?
  10. paddy
    5,152
    133
  11. NHN
    29,298
    1,701
    I was about to say, check your handbook as all in there.
    TBH I would check fuses with a multimeter for continuity as sometimes we miss the blown ones & econ light could be a fan fault tbh, check fan fuses as in fans on front of car.
  12. paddy
    5,152
    133
    Yea your right.....I am just feeling helpful today........very strange :) I had a swine flu jab this morning...could be something to do with that ? I'll let you know if i start squeeking .
  13. NHN
    29,298
    1,701
    lmfao
  14. paddy
    5,152
    133
    Do i take it you abroad at the moment Nige ??...........Bad news is Surrey and Sussex have been washed and blown away today.....Good news?
    You can get a cross channel ferry back to Sevenoaks now :)
  15. Khufu
    5,704
    31
    :( It's looking grim down there!
  16. paddy
    5,152
    133
    Your not wrong Kh...and it aint the weather
  17. NHN
    29,298
    1,701
    Yeah, even more last night with the sangria & pizza, lol.
    lmfao, but not so good, Sevenoaks, ah man, I'm a Kent born man, but preferably not ferry there, lol
    lol, I'll say it again mate u crack me up.
  18. johal87
    johal87 Member
    331
    Guys ur legends!
    Fuse f1 was really really dirty so I don't think it was making a connection
    so cleaned the inside with some compressed air and put another fuse in, only had a 25amp so I will replace it with a 30 when I go out
    as soon as I took the car over 15mph lights went off and my dash don't look like a Xmas tree anymore
    can't thank you guys enough!
  19. paddy
    5,152
    133
    Well done , its always satisfying when you stick with it and get a result,, what about the econ light ? thats usually a sign it needs re gassing.
  20. NHN
    29,298
    1,701
    Personally, I would of left the lights there as would of looked great for xmas :undwech:
  21. johal87
    johal87 Member
    331
    LOL yeah bit early for a xmas tree thou hey, touch wood they wont come back!
    yes its great when you can say you fixed something your self, with you guys advise and knowledge of cause!
    also - ECON, the car does need regassing, so thats next on the list, any recomendations?
    Cheers again fellas
