Tracking issues?
jonny87 Dec 22, 2009
  1. jonny87
    jonny87 Active Member
    1,094
    well after two weeks in the bodyshop i finally got my s3 back, awesome job by the bodyshop, so a big shout out to kustom 101 in teweksbury and geoff smith whos in charge
    anyway got it home and took it to get my new rims fitted and balanced then tracking reset after smashing the kerb, driving it home and it still pulls to the left, and at low speed the steering wheel wobbles gently from side to side and at high speed (80-90) that turns into a very bad vibration
    also when i was looking at my rear tyres that came off the car, the one (passenger side) has been scrubbing out on the inside edge, would this explain why the tracking is still out if they have set the fronts to the rear?
    regarding the vibration my mate suggested swapping the front wheels with the rears to see what difference if any that would make, but should i look for something i may have bent when hitting the kerb, not sure what, a tie rod bar, lower suspension arm??
    thanks in advance you lovely lot!!
  2. jonny87
    1,094
    bump, anyone any thoughts?
  3. Sandip
    2,440
    91
    Its likely that your old rears were once on the front, now that you've got all your new wheels and tyres i'd get them balanced again and get the 4 wheel alignment done
  4. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,132
    1,971
    I agree with sandip
  5. jonny87
    1,094
    the rears couldnt of been on the front as they are wider and would rub on the arches, so they were always on the back
    as said when the tyres were fitted onto my new rims they were balanced before being fitted to the car, and i had the tracking done straight after the new wheels being fitted
  6. Sandip
    2,440
    91
    How big were your old wheels? New tyre do sometimes need re-balancing once they've bedded in, i still recommend 4 wheel alignment
  7. jonny87
    1,094
    old wheels were 235 35 19 front 265 30 19 rear
    new wheels are 235 35 19 all round
    a mate suggested swapping fronts with backs as the one tyre which is on the front is the one which took the impact of the kerb a few weeks back and said that could affect it
    il try and find somehwere round by me that does a 4 wheel alignment, cant think of anywhere off the top of my head
  8. Sandip
    2,440
    91
    265's would explain the uneven wear, thats a little too wide, i run 235 35 19 on 9j bbs's, lowered on kw springs and standard tie bars and the wear is even both front and rear.
    Best thing is re-balance and alignment then see how it goes from there:thumbsup:
  9. jonny87
    1,094
    yer, its gonna stay like it for now though what with xmas etc
    just strange how only the one tyre off the back worn unevenly and the other was ok, still il get the wheel alignment done and a balance and like you said go from there
    il let you know how i get on :thumbsup:
