Track tyre pressures
S3 TAM Oct 29, 2012
  1. S3 TAM
    S3 TAM Pocket now empty
    624
    10
    Hey everyone as the title says what would be the best starting pressure i.e. when tyre is cold.
    Avant ad048's
    225/45/17
    And also
    195/50/16
  2. camscockle20vT
    camscockle20vT The stigs ugly brother
    1,740
    78
    I have no clue mate, check out prawns build thread, or message him.
  3. Westy
    Westy Well-Known Member
    17,443
    1,105
    Mate we just need to blast round then come in and try to get them at 30/32psi when hot. Can't really set tyre pressures up when cold for the track.
  4. StaceyS3
    StaceyS3 Well-Known Member
    2,505
    502
    Ahh was going to also post something simular up but am going to be really cheeky and tag along ;)
    AD08's 225/40/18
    Conti sport 5's 225/35/19 (only if it's really wet)
  5. StaceyS3
    2,505
    502
    Have either of you got some form of pump or wee little compressor as may let to much out and I've got a slow puncture ;)
  6. Jason.s
    Jason.s Active Member
    2,879
    348
    Lol! You'll be fine. Often driven back from drag strip with less than 20psi in the front. There's a bp just down the road too if its bad. Usually where you go to fill up at lunch if low on fuel.
  7. Westy
    17,443
    1,105
    I've got a gauge that let's air out too but nothing to pump up. We'll be fine.
  8. jojo
    28,985
    3,630
    Trial and error Tam. For open pit lane, adjust the tyre pressures lap by lap, using one specific corner for reference which is what I did. I have a halfrauds foot pump with pressure gauge on it! lol :p
  9. Prawn
    11,636
    3,624
    aim for NO MORE than 30 psi hot Tam, I'd suggest starting out at 26psi all round at first on the 225/45/17's, perhaps dropping them a bit further if they exceed 30 hot. How much they heat up will depend on how you drive it, I start mine at 24psi cold now.
    For the smaller tyres you can go even softer, A friend of mine with a mk2 golf track car on R888's in 195/50/15 runs 26 hot with fantastic results!
  10. S3 TAM
    624
    10
    Cheers for the input guys.
    I think i'll start out on 26psi and see how i get on. Hopefully it wont be a wet one so i can get to try out my new/part worn ad048's.
  11. superkarl
    superkarl MAN OF STEEL
    9,590
    2,473
    like jojo said, its a case of trial and error.
    my boss told me that when racing they'd have to check every lap during practice, and inflated/deflated in incriments of 0.5psi. And that starting too soft the tyre heats up quicker, so its not a case of starting low and hoping it gets to a decent hot pressure, because you might find you can start harder and still have the same hot temp.
    anyway thats being pedantic, no one actually cares in the real world. so just go out and ****ing eat some porsches
    Westy likes this.
  12. jojo
    28,985
    3,630
    I was changing mine by 1psi by lap, and the difference was either grip or understeer for one corner in my car.
  13. superkarl
    9,590
    2,473
    I was using my bosses case as an example. He races
    I asked him the same question before the ring and also adi ya see, and he went into the ins n outs of tyre pressures, like I was racing lol.
  14. aragorn
    18,577
    868
    Depends on the weight of the car too.
    A full fat S3 will need more pressure than a stripped out A3 which in turn will need more than a featherweight mk2 golf.
    Toyo R888 for instance recommends the folowing:
    Below are some basic settings:
    VEHICLE WEIGHT COLD PRESSURE HOT PRESSURE
    Very Light < 800kg 17 - 22 psi 22 - 29 psi
    Light 800kg - 1000kg 20 - 26 psi 24 - 32 psi
    Heavy 1000kg - 1400kg 23 - 27 psi 28 - 40 psi
    Very Heavy > 1400kg 27 - 35 psi 37 - 40 psi
