Here is a little update, the weekend before last we removed the rear axle from the car, we then separated the hubs from the rear axle. Over the week we pushed the bushes out the axle and new/old wishbones. We then removed the bearings from our new/old hubs. We did removed the subframe to push the bushes out but then found it was past it, so nick has sourced one and it is on its way to us. We have sent our rear axle, front wishbones and hubs to get them powder coated.
Today we decided to do some more work. So we started by removing the rear shocks. We then removed the old steering rack as we have an S3 one to replace it. And then disconnected the drive shafts from the diff. We then removed the calipers and started to undo the strut top mounting nut...we quickly came to a hurdle because we didn't have the correct tools to undo the nut so we just drilled the middle out of the strut and dropped the strut, hub and drive shaft all in one.
We now have no suspension, steering or even any where to put a wheel on the car now.
We are ready to change the gearbox, clutch, sump, cambelt, steering rack, suspension, bearings, bushes and started motor within the next 30 days before the track day.
